What to look out for 00-01?
Old May 2, 2005 | 06:31 AM
MaxKlinger's Avatar
Hey guys,
My buddy's looking to get an 00 or 01 Maxima. He's looking at different cars, and asked me what he should look out for. I advised him to find a 5-spd, but if he was looking at automatics he should check the trans fluid to make sure it was nice and cherry colored. Also, I suggested he check the underside of the car for leaks, CVbooot condition, etc. Off the top of my head I couldn't think of much else...
Is there anything that he should specifically check in an 00 or 01 before buying?
Old May 2, 2005 | 07:02 AM
JustinMKN's Avatar
00's
I have a 2000 GLE. It had Engine Coil problems that hit me around 43k miles. I'd go with a 2001 model if you can. Check out the rear tray rattle too when you turn up the base.
Old May 2, 2005 | 07:05 AM
Bobo's Avatar
Demand the maintenance history for the vehicle. I am constantly amazed that buyers don't obtain this. I would be somewhat skeptical about buying a car if the owner/vendor didn't provide the mntce history, as it tells a lot about what has been done and consequently, what may need to be done.
Old May 2, 2005 | 08:22 PM
MaxKlinger's Avatar
Yeah, the maintenance history is key, I already advised him to do so and he agreed it was important. I was just looking for anything specific to the 5th gen cars, to watch out for - common problems, unusual traits or tendancies. I don't really expect there to be much since the Maxima is such a high-quality car, but I figured I'd check with the 5th gen folks...
anybody with other thoughts?
Old May 2, 2005 | 08:23 PM
LithiuMax
Look out for that small 3.0L engine.
Old May 2, 2005 | 08:27 PM
Whtmax'01's Avatar
rotors wear out quickly, mass air flow sensor issues, many have experienced the catalytic converters and/or ecu faulty causing the P0420 code. Dealers sometimes can fix this. Watch for tranny slippage if it auto.
Old May 2, 2005 | 11:25 PM
maseo77's Avatar
Just watch out for faulty coil packs
Old May 2, 2005 | 11:27 PM
SixxOne's Avatar
cheap paint
Old May 3, 2005 | 06:28 AM
MaxKlinger's Avatar
Hey now...
So coil packs will cause irregular firing, correct? Therefore if an engine is idling and revving smoothly, there should be no coil pack issues (yet). How much do they cost to replace (I've never had to replace one). Should my friend demand to have the computer codes pulled at the dealer to prove that there are none in the system (there can be silent codes, correct?).
Old May 3, 2005 | 07:30 AM
Max_Gator's Avatar
Originally Posted by MaxKlinger
Hey now...
Unlikely you'll see any problems at idle. Usually you get detonation under load that you wouldn't normally get. Frequently no codes - but if you do get one - 1320 it will set the light off.
Old May 3, 2005 | 05:34 PM
SCT.MAX's Avatar
Brakes .... It would be great if the front rotors were replaced with aftermarket (originals are crap). Rear deck rattle ... Turn the audio up, listen for rattles. Hopefully it was already taken care of. There is a TSB on this. Original rear suspension is too spongy with three or more adults inside. The best thing to do is get a '02, all these things and more were corrected in the '02, and even more in the '03.
Old May 3, 2005 | 05:47 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Get an '02-'03...an extra gear. +0.5L, and DDEs are reason enough!
Old May 4, 2005 | 12:16 AM
3x10^8's Avatar
Relying on the codes to detect any problems is fairly, well, unreliable. Those codes can be cleared with the proper equip. And they usually take a bit of time to come back, probably quite a bit after the dealer's sold you the car. Just my $.02...
Old May 4, 2005 | 09:07 AM
MaxKlinger's Avatar
I agree with you whole-heartedly...but I'm not the one buying the car and I don't think horsepower is priority one for my friend (he's also looking at a 5-spd Altima 2.5S). Having driven my dad's '02, I have come to love the VQ35.
What are DDE's?
This is very true...I don't know if this goes for the 5th gens, but you can clear the 4th gen codes with a screwdriver in about 60 seconds.
Y2KevSE
72
Aug 4, 2008 08:21 PM
grille-tech
Dec 28, 2002 03:36 PM
StillenSzuChen
18
May 29, 2002 02:26 PM
maximaman69
Aug 25, 2001 04:36 PM
