I Need Help.
Old May 4, 2005 | 05:56 PM
MY2000MAX's Avatar
I Needed Help.
I was driving on the highway and as i was makin a turn on my exit i had a big problem. My wheel locked up and my dash lights went on. The car stalled as i was haulin *** off a turn.
I restared but it kept dyin on me. The RPMs would shoot up to between 2 and 3 and go all over the place and in a few moments it would die again.
Luckily, i live next to the highway and managed to get it home after stalling another few times.
WDF is goin on with the car. First time ever experiencing this problem. Any help wil be greatly appreciated.
Old May 4, 2005 | 06:10 PM
jyardog's Avatar
I had an IACV fail on my 2k1, the car just would not idle, it ran normally other than that and the CEL came on. It threw P0505 code.
Old May 4, 2005 | 06:14 PM
NuJerseyDrive's Avatar
That happened to me while trying to make a turn as well. It was really scary since I stalled out obstructing incoming traffic...thank God I wasn't holding my DD coffee.
My ride would stall out from time to time and the engine would race up and down as well. For me it turned out to be 2 things, a dirty throttle body and a clogged IACVV (sp?).
Pick up some carb and choke cleaner and clean out your TB. That "should" correct the stallin out.
The valve which I think is known as the Idle air control valve is really cheap so maybe this whole problem will turn out to be a cheap and easy fix. Good luck.
OT - Does anyone know what happened to this site? http://www.motorvate.ca/mvp.php Hope it's not dead =/
Old May 4, 2005 | 07:30 PM
sascuderi's Avatar
Blown MAF?
Old May 4, 2005 | 07:43 PM
MY2000MAX's Avatar
i just reset the ECU to see what would happen. same results and it threw the SES light on almost immediately.
Old May 4, 2005 | 08:11 PM
MY2000MAX's Avatar
I couldnt find the instructions of how to clean the throttle body. Any one got a linky?
Old May 5, 2005 | 07:02 AM
MY2000MAX's Avatar
bump.
Old May 5, 2005 | 07:24 AM
you're in luck. this site is back http://www.motorvate.ca/mvp.php/517
Old May 5, 2005 | 09:32 AM
MY2000MAX's Avatar
Even when the car starts fine and looks pretty stable, i still dies as soon as i drive to drive. And it feels like its dyin when i come to a stop.
Somehow i think this problem is gonna cost me a sh1tload.
Old May 5, 2005 | 09:41 AM
have you cleaned out the TB yet?
Old May 5, 2005 | 09:48 AM
MY2000MAX's Avatar
i bought the cleaning solution for it. I got the instructions from that site you gave me but was totally confused.
Old May 5, 2005 | 10:10 AM
What part confused you? That write up made things real clear for me.
Old May 5, 2005 | 10:16 AM
MY2000MAX's Avatar
the pics, i couldnt really tell what needed to be removed
Old May 5, 2005 | 06:09 PM
MY2000MAX's Avatar
I will try the cleanin the TB tomorrow. If i cant fix it myself i know where my tax refund is going.
Old May 12, 2005 | 08:43 PM
MY2000MAX's Avatar
It was the valve. I had to have the valve assembly replaced. The part itself was about $230 form the dealer. But i managed to get it for $190 from him. Thats just for the part. This isnt exactly a DIY job.
Old May 12, 2005 | 09:47 PM
Bensmax00's Avatar
dude take the intake off and spray some carb cleaner on a rag and wipe the inside of the throttle body--open it up and get as far in as you can--we usually do this for a sticky gas pedal--but if its excessive can do that--never really seen it though--cuz whlie at idle the throttle does not close all the way--it is open just a hair--
Taino14
Sep 24, 2015 02:51 PM
hozay99
Sep 19, 2015 10:20 PM
pears
Sep 18, 2015 05:25 AM
