Help with my brakes please..
Old May 5, 2005 | 04:28 PM
Bl_asd's Avatar
I decided to do my brakes today since i got my rotors and pads from group deal... anyway... I couldn't even loose the lugnuts...they are just too tight to take off..any way to get them off easily? also...will my 4" c-clamp work for both my front and rear brakes?
Old May 5, 2005 | 04:33 PM
SgtSchulze's Avatar
Burn Dust. Eat my rubber.
Put a bar over the lug wrench (i.e. breaker bar) and push/pull like hell.
C clamp works for the fronts only.
Need the special rear caliper tool (less than $10) from your local auto parts store.
Good luck!
Old May 5, 2005 | 05:37 PM
FanaticMadMax's Avatar
You mean you can't get the lug nuts off your rims? Seem like it shouldn't been that tight. As for your calipers, with the rears, you can't use c-clamps, you have to get a special tool, that you have to turn the piston to go in since it doesn't use lateral force to press it in.
Old May 5, 2005 | 05:41 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
you can also rent the tool from Autozone....
Old May 5, 2005 | 07:19 PM
taekwondodude's Avatar
You could Try using an Impact Wrench to get off the lugs
Old May 6, 2005 | 03:31 PM
screamindman's Avatar
Go to AutoZone and get a break away spray similar to liquid wrench or something. When I did mine, we used the cheapest looking stuff and it worked awesome.
Old May 6, 2005 | 07:41 PM
swiss_alps's Avatar
Do any of you use break dust guards?
Old May 6, 2005 | 07:55 PM
max 01's Avatar
Stubborn Lugs...
I always end up stripping and having to replace a stud or two when I take off my rings and no, I am not over tightening them...I think. I think all would agree...the last place you want liquid wrench is on your lug nuts..unlesss you clan it like hell before replacing your tire.---turn 100mph..think about it...
Old May 26, 2005 | 04:57 PM
CEFIRO's Avatar
Ha the other day i was trying to replace my rear and tried everything, now i know its not using the c-clamp. Im on my way to the autoparts!
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
