New throttle body
Old May 8, 2005 | 07:32 PM
icewake's Avatar
New throttle body
Has anyone put a new throttle body on their max? if so which one and what were the gains on them. also, what was the size of the new and what is the size of the stock one? thanks.
Old May 8, 2005 | 07:56 PM
TheBigDu's Avatar
I have never heard of this being done on a Max. Don't think anybody makes an aftermarket TB for us.
Old May 8, 2005 | 08:00 PM
irish44j's Avatar
retired moderator
Didn't BlackbirdVQ put the Pathfinder TB on his?
Old May 8, 2005 | 08:06 PM
killerVQ30DE's Avatar
Maybe only for 4th gens.. but people put Nissan Pathfinder TB's on due to the larger dimensions... no ones really proven a lot of gain I don't think
Old May 8, 2005 | 09:34 PM
frankd121's Avatar
A bigger tb won't do much for those with just bolt ons. for FI apps, a bigger throttle body will help out noticably since you're forcing that much more air into the engine.
Old May 9, 2005 | 06:40 AM
kcowden's Avatar
You might want to check this out. www.proflowdesign.com
Old May 9, 2005 | 02:01 PM
icewake's Avatar
it shows that they have a throttle body for the max but i don't want to spend that money and not get gains. and i do plan on putting a CAI on it sometime
Old May 9, 2005 | 10:58 PM
panda_1's Avatar
or instead of buying a new one, you can just bore out the stock tb, checkt out http://www.maxbore.com nice guy located in florida, had a friend wit a 3rd gen get his bored out, not sure how big though. out of curiousity how big is the dimensions on our stock tb?
Old Jun 5, 2005 | 08:32 AM
sclebo05's Avatar
thanks for the link.
Old Jun 5, 2005 | 09:01 AM
importuner
Changing to a bored out tb will give a small amount of gain, but will hurt more than actually help performance. Your air/fuel ratio will be bad considering the increased amount of air coming into the upper plenum. If you have a CAI this issue only makes the matter worse. When doing this modification you want to have other mod's to back it up. Such as: APEXi S-AFCII, Bigger Fuel Injectors, Headers-Y-Pipe, Cattback Exhaust, etc. If you decide to swap your tb for a bigger one w/o modifying fuel your car will be running like garbage (extremely lean). Not enough fuel to air ratio.
Old Jun 5, 2005 | 09:31 AM
Nissan SE-R's Avatar
Actually, the MAF helps the ECU compensate for the additional air flow. The difference of air flow is very minimal. What you will gain is a bit of throttle response. Also remember that since we have a throttle by wire set up, the ECU can limit how much the throttle opens for any given pedal position.
Old Jun 5, 2005 | 09:55 AM
nailz420's Avatar
throttle by wire is for 5.5+ gens only
Old Jun 6, 2005 | 07:05 AM
woosh's Avatar
You can easily test it if you have a 2k or 2K1. There is a spacer sleeve inside the throttle body.
As fasr as I know the ppl that removed it said they felt low end torque loss and felt a little gain in the upper rpms.
~catch me if you can like the ginger bread man
Old Jun 6, 2005 | 07:39 AM
icewake's Avatar
I thought is would help low end torque thats what i want to gain
REDinLV
Aug 15, 2024 12:30 AM
msellas
Sep 23, 2015 09:16 PM
220k+ A32
Sep 23, 2015 03:38 PM
bumpypickle
Sep 20, 2015 08:22 AM
followthadollar
Sep 13, 2015 09:55 AM
