Rear Caliper Toast??
Old May 9, 2005 | 12:07 PM
drdrum's Avatar
My rear driver caliper is off the car and i'm turning the piston with a tool, but it's not going back into the caliper. It's about still 3/4 inch out from flush and won't go over the new pads.
Do I need to apply a bunch of pressure AND twist to get those back? Or is twisting itself enough. Basically, I'm wondering if I'm not using enough might, or is my caliper busted if it won't go back?
thx!!
Old May 9, 2005 | 12:22 PM
spirilis's Avatar
I know you have to twist it a lot of revolutions... it shouldn't hurt to apply some pressure too. Try that.
Old May 9, 2005 | 12:59 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
That happened to me too and what I did was I put a lot of WD40 in it and pu**** as hard as I could.. thew caliper is fine trust me...
Old May 9, 2005 | 01:39 PM
Matt_01SE_20th's Avatar
this was a pain in the *** when i did it but yes just push it as you twist. it helped me to open the bleeder too.
Old May 9, 2005 | 01:55 PM
drdrum's Avatar
if you open the bleeder, do you gotta do a full brake bleed, etc.?
Old May 9, 2005 | 04:39 PM
Lontar1's Avatar
no you don't....but might do it just in case
Old May 9, 2005 | 07:50 PM
BrandonSE's Avatar
lol this happened to me and i took it to 3 different mechanics, they all said bad caliper it shouldn't be that hard, and it seems that all of a sudden alot of us 00 and 01 owners are experiencing bad rear calipers... once again another reason why i will definitly buy another nissan
Old May 10, 2005 | 05:23 AM
Y2KMaxGXE-R's Avatar
I also need the caliper. Where can I get the best deal? Would you recommend buying a used caliper?
Old May 10, 2005 | 05:58 AM
drdrum's Avatar
calipers are fine !!
Well, had I listened to the nissan stealership lack of service shop manager about my rear caliper, i'd be out another 100 bucks. He said if the piston doesn't go in after turning, it's a bad caliper. nope, you gotta PRESS and turn using a piston retractor tool FREE at Autozone that uses a plate to provide backpressure against the caliper arms while simultaneously turning the piston. This worked like a charm and my brakes feel awesome today. I broke them in slowly last evening. My rear brakes (mind you my first time) took me only an hour with that tool. Rotors and pads.
Seriously, Nissan service shops truly do suck A$$.
My first mod, brembo slotted rotors / PBR axxis pads. also my first brake job!
rock on!
Old May 10, 2005 | 06:14 AM
I have a feeling that my mechanic is trying to rip me off by telling that I need a new caliper.
Basically, he got the car on the lift, and turned the rear wheel without taking it off. The wheel won't turn.
Old May 10, 2005 | 06:49 AM
Digger01's Avatar
I would take the caliper off, and clean it real good by taking it apart/lube it up with "Ultra disk lube". there is a good how to write up on www.motrvate.ca , hope it helps.
You could also send your caliper to a refurbishing place for them to Recondition it..$80 i think. They need your core, so the car will be down during this time.
On another note i heard you can install a brake caliper from a 300z or infinity caliper on the Max, especially for the front, does anyone know if they will fit under the tire 17"
AcuraLegend
Oct 17, 2016 08:47 PM
BkGreen97
Apr 2, 2016 05:47 AM
AcuraLegend
Sep 22, 2015 04:22 PM
bbsitum
Sep 11, 2015 04:55 PM
beerman1378
Sep 8, 2015 02:19 PM
