Hood making noise
Old May 16, 2005 | 01:55 PM
bladerunr's Avatar
Hood making noise
Riding over small bumps and road imperfections at moderate speeds I seem to notice a rattle coming from the engine/hood area. I assume it's the hood rattling. I only have 26k miles on the car so it shouldn't be the suspension. Has anyone else seen this and what did you do as a remedy? Thanks for the help.
Old May 16, 2005 | 01:59 PM
2k2nyc's Avatar
i had the same problem, just twist the rubber bumpstops (which the hood rests on)counter-clockwise so that the hood is more snug when closed.
Old May 16, 2005 | 02:20 PM
LA02MAX's Avatar
i did that, and it didn't really help hood flutter at highway speeds, and it made the hood noticably higher...the hood didnt match up with the fenders and there was quite a big gap in between the hood and the headlights, so i twisted them back.
Old May 16, 2005 | 03:51 PM
-Red-'s Avatar
Take some thick 3M clear tape and wrap it around the hood latch a couple of times. I had the same problem with mine a while back, and that worked great.
Old May 16, 2005 | 04:12 PM
BP's Avatar
BP
my hood looks like it's gonna fly open whenever i'm on the highway. i just ignore it now.
Old May 16, 2005 | 04:25 PM
Epacy's Avatar
Unsuccesful STL Coordinator
those bumpstops are the fix
if that doesn't help, then remove the pistol you carry under the hood
Old May 17, 2005 | 02:08 AM
Dave2112's Avatar
WD 40. My hood did the same thing so I sprayed the hook assembly with WD, and now, no more noise.
Old May 17, 2005 | 04:23 AM
takkar's Avatar
i hear a rattle everytime i close my door...it's definetly coming from the hood...tried wd40 and that doesnt help...need to put some some rubber around the area where it is rattling.
Old May 17, 2005 | 04:39 AM
2k2nyc's Avatar
mine rattled when i closed the door also.......adjusting the bumpstops solved the problem.
Old May 17, 2005 | 04:49 AM
Spin20's Avatar
I just lowered the hood latch, there are about 3 or 4 screws on it, I loosened them and moved the entire latch assembly down a tiny bit, Problem solved!
Old May 17, 2005 | 06:16 AM
bladerunr's Avatar
Thanks for the suggestions. I've tried raising the bumpstops and it seemed to make it worse. I'll try the other suggestions. Is it my imagination or are we supposed to have a rubber guide above each fender. There is a slot where a rubber bumper guide could sit in but nothing came with the car. If we could find something to put there it might keep the hood more snug. I put some guide stops in there from a Gen 4 but they were to small to fill the large gap between the hood and fender.
Old May 17, 2005 | 06:26 AM
jyardog's Avatar
I saw a TSB a while back about hood flutter and the fix was a couple of rubber strips that attach above the headlights and a third rubber bumper installed front, center of the hood behind the latch.
Old May 17, 2005 | 09:24 AM
shoman94's Avatar
You are correct....there is a TSB for that issue....
--Jason
alahjahwan09
18
Sep 21, 2015 09:12 PM
jfl330
Sep 4, 2015 01:44 PM
Justin Kroll
Sep 2, 2015 11:06 AM
