Can I upgrade the Alternator on my 5th gen!
Old May 24, 2005 | 07:30 PM
under5295's Avatar
I want to move up to a high-output alternator...any ideas what I can use.
my reason for moving up is the streo plans I have will probly kill the stock alt.
Old May 24, 2005 | 07:36 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Dude, you JUST asked this in the audio forum.
YES, you can upgrade; NO you don't need to.
Again, are you competing in SPL leauges or simply uneducated?
there is NO need to upgrade unless you are running a true 2kW. Additionally, there are a number of additional electrical components that will be affected by this upgrade.
Ground the ish out of your car w/ 1/0, upgrade your big 3, get an optima, and call it a day.
Old May 24, 2005 | 09:46 PM
screamindman's Avatar
I don't run a huge system (alpine v-12 4x40? and an Extant mono bass amp 1x200 watts I think) and my amps killed the alternator after 33k miles(didn't have the OPtima until now). Get a real good stiffening capacitor, the above mentioned optima, use good wires and gold fuse blocks all throughout, and use good grounds.
Old May 24, 2005 | 09:53 PM
xtantmaxima's Avatar
My alternator is still churning along, but an upgraded alternator would help out. I have an Xtant 2200 and 1001 running at 1ohm. It pulls between 150-200A. You can get your stock alternator upgraded or send a core in and get it "rewound" and you'd be all set. Good luck.
Old May 25, 2005 | 06:54 PM
amomaxima's Avatar
where can you send it in and how much does it cost i have the same problem but i am only running and 1000 watt and a 800 watt
MAXSE5SPD
Sep 17, 2022 04:00 AM
iflexsteel
Sep 2, 2015 08:04 AM
Lowered_a33
Sep 1, 2015 07:49 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
