Windows open and close slowly and noisy, help.
Old May 25, 2005 | 08:04 PM
Whtmax'01's Avatar
Windows have gotten so slow upon openning and even worse when closing.How do i resolve this problem?
Old May 25, 2005 | 08:24 PM
meccanoble's Avatar
Sports Button FTW
rubber lubricant and rain x....i hear do the trick. Very common on 5th gens like warping stock rotors....
Old May 25, 2005 | 10:19 PM
darrick04's Avatar
Same problem here... Squeaky as hell...
Old May 26, 2005 | 02:59 AM
lalaMAX's Avatar
same here tried silicon lube, but no luck anyother help?
Old May 26, 2005 | 04:03 AM
TDotMax's Avatar
Same prob here, now passenger side window will only go down, can only put it up from driver side switch.
Old May 26, 2005 | 11:15 AM
meccanoble's Avatar
Sports Button FTW
wow, if its been doing this for a while your module or motor may be bad....
Old May 26, 2005 | 11:18 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
A grounding kit will work wonders for this...
Old May 26, 2005 | 11:58 AM
Y2KMaxGXE-R's Avatar
a silicone spray that costs $4 a can, just spray it well in the right places, that'll fix it
Old May 26, 2005 | 12:30 PM
Klutch's Avatar
Sounds like the regulators are going out.
Old May 26, 2005 | 01:28 PM
SoonerFan's Avatar
Cletus
here is how you fix the problem
blue and red line - wipe with wet washcloth to get all the dirt out. make sure to get inside the channel
red line - silicon spray to lubricate the channel
Old May 26, 2005 | 01:49 PM
zax 20th ae's Avatar
Soonerfans advise helped me....
But you will come across the problem later down the road once the lube
starts to wear off.
Old May 26, 2005 | 02:00 PM
SoonerFan's Avatar
Cletus
starts to wear off.
well there is no way to completely eliminate the problem. the channel gets dirt in it and dries out
Old May 26, 2005 | 02:04 PM
Right, so whenever the problem starts to come back i wipe em and lube em again.
Im satisfied.
Old May 26, 2005 | 11:34 PM
lalaMAX's Avatar
no lube on the blue line?
Old May 30, 2005 | 05:24 PM
SoonerFan's Avatar
Cletus
NO..you will get streaky windows from the silicon.
the main resistance comes from the channel window is in, so you need to lubricate that. the sound is from the horizontal rubber piece being dirty
Old May 30, 2005 | 06:22 PM
Rube0023's Avatar
I had the same problem, driver side front window was soo squeaky and slow going up and down. I cleaned out the channels that Soonerfan pointed out and sprayed some silicone lube in the red channel. There is one additional horizontal channel where ALL my noise was coming from. Its the front part of the window channel, right on the inside of the outside mirror, I sprayed that and voila my squeak was gone. Window rolls up and down nice and quiet and much faster too. I figured if I left it that way, I would have toasted the window motor.....it was that bad.
Old May 30, 2005 | 06:23 PM
Rube0023's Avatar
Oops, I meant the VERTICAL red channels......
Old May 30, 2005 | 06:33 PM
SoonerFan's Avatar
Cletus
RWCreative
Sep 21, 2015 11:01 AM
pears
Sep 18, 2015 05:25 AM
Vequity
Sep 10, 2015 05:26 AM
