steering wheel removal
Old May 28, 2005 | 08:07 PM
Teufelhunden's Avatar
whats up guys.
i recently got an alignment done, since my car pulled to the right and my steering wheel was crooked towards my left.
since i got my alignment done, it doesnt pull anymore, but the steering wheel is bit off to the right. i wanted to take it off and realign my steering wheel to the center since its bothering me. anyone know how to take the steering wheel off?
i see two screws on the side of the wheel covered in plastic, its in some kind of weired shape, do i need to remove that? i need help.
Old May 28, 2005 | 08:10 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Your car hasn't been properly alligned if that's the case. Do you think Nissan mounted your steering wheel crooked from the factory?
Old May 28, 2005 | 09:05 PM
P. Samson's Avatar
This has been covered before. DO NOT attempt to remove the steering wheel. After an alignment if the steering wheel is off center then the outer tie rod ends are differentially adjusted to "center" the steering wheel. Be aware a perfectly aligned car with a "perfectly centered" steering wheel will probably still exhibit a slightly left of center steering wheel off center condition when driven on a "normal" road. This is because most single lane roads are not flat but crowned and are sloped to the curb side.
Old May 29, 2005 | 09:40 AM
oh well, i guess i cant remove it? thanks anyways. ill just have to live with it
Old May 29, 2005 | 09:41 AM
no but my car is lowered, so i thought maybe that was the reason why it was still crooked.
Old May 29, 2005 | 04:36 PM
P. Samson's Avatar
Why would you "live with it"?? Take it back to the place where you had the alignment done, tell them which way and how much the steering wheel is offset (they hopefully may drive the car to see for themselves) and they will adjust the outer tie rods (differentially) to bring the steering wheel back to center. It doesn't take long.
Old May 30, 2005 | 12:01 AM
vsamoylov
so will they have to do a alligment again or just adjust the tie rods?
Old May 30, 2005 | 12:05 AM
SEmy2K2go's Avatar
Go BUCKS!!!
My car is lowered too. I'd recommend having the business that alligned your car, try again.
Old May 30, 2005 | 02:02 PM
P. Samson's Avatar
They will only have/want to check TOE. All that they are going to do is lengthen one tie rod by lets say 1/4 turn and shorten the other one by 1/4 turn.
Old May 30, 2005 | 02:41 PM
vsamoylov
yeah thats good to hear because i dont want to pay for a full allingment.
Old May 30, 2005 | 06:33 PM
ok thanks guys, ill go back tomorrow, and make them do it over.
Old Jun 5, 2005 | 08:48 AM
sclebo05's Avatar
give'em hell!
lowpost99
Oct 26, 2025 06:53 PM
dcam0326
Sep 8, 2015 11:02 PM
lowpost99
Sep 8, 2015 05:06 AM
jfl330
Sep 4, 2015 01:44 PM
coasterswim
Sep 2, 2015 07:43 AM
