Brembo G35 calipers...Can it be done???
Old May 31, 2005 | 09:56 AM
Battle Max's Avatar
Ive been searching over the past couple of days to find answers regarding this issue and i cant seem to come up with any. I basically was given the brembo calipers from our g35 drift car and i dont know if the task of making them work with a bbk is cost efficient or worth it. So basically please give me some feed back from some of the brake guru's
Thanks,
Jon
Old May 31, 2005 | 10:02 AM
Jeff92se's Avatar
I'm needing a caw
You will need custom brackes, some appropiate rotors with the correct offsets, custom brake lines and then make sure your wheels can clear the calipers.
But if you are lucky, maybe Brembo custom made these calipers to Nissan/Infiniti oem torque members. If you have them on hand, just take off your caliper and test fit.
Old May 31, 2005 | 10:09 AM
MaximaSE9696's Avatar
bump for that, can it be done, that would be a sick a** upgrade
Old May 31, 2005 | 11:59 AM
A33 VQ30DEK's Avatar
THey are sick, but they're only 2 piston calipers compared to the 300zx 4 piston ones. =)
Old May 31, 2005 | 12:26 PM
scopium
i'm not a guru.. but i saw it done on a sentra
Old May 31, 2005 | 01:05 PM
the sentra SE-R specv have an option of the brembos.
Old May 31, 2005 | 01:17 PM
irish44j's Avatar
retired moderator
send them to me, I'll make sure they fit
Old Mar 24, 2006 | 12:47 AM
DeusExMaxima's Avatar
Did they work?
Old Mar 24, 2006 | 09:34 AM
NmexMAX's Avatar
dot dot dot ...
Were you referring to the front or rear?
From NissanNews..
http://www.nissannews.com/infiniti/2...pe/index.shtml
BremboŽ brakes
Front: 12.76-inch x 1.18-inch power-assisted - 4 pistons - S
Rear: 13.07-inch x 0.87-inch power-assisted - 2 pistons
Apr 16, 2020 05:15 AM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
thatcollegestudent
18
Oct 5, 2015 02:29 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
