GAS Tank Door
Old May 31, 2005 | 05:02 PM
Bondy009's Avatar
GAS Tank Door
This is happening for the 2nd time. The door that opens/leads to the tank is stuck. I press the open button inside of my car and nothing.....This has happened like 3 times already and it alwasy happenes when I am on the low end...The last time I had to force it open with the screwdriver becuase I was really really low on gas. Anybody know what might be happening, I kno its electrical but is it anything I can fix?
Old May 31, 2005 | 05:15 PM
Army of Maxima's Avatar
Looking for a few good Maximas
Have you tried checking for rust/dirt/grime/gunk in the hinge and release area? Clean it up and it *should* pop right out.
Old May 31, 2005 | 07:07 PM
instil's Avatar
I had to replace my driver side mirror, so i had to take off the door panel. When i put everything back together, no gas tank release.The button did nothing.
this was because i never hooked back up the electrical connector for the gas tank/trunk release. Did you disconnect that recently???Does your trunk release work?Do you hear/feel it pop the door when you press the button,or do you get nothing at all. See if that connector got loose or you never put it back on.
Old May 31, 2005 | 07:10 PM
Bondy009's Avatar
UPDATE!!! After like 30 presses it opened, I then closed it and tried it again....NOthing...I took a screwdriver and had a priend depress the button while i opened it. I snapped the little black thing holding the door and will be going tomorrow to replace it....Is it an easy part to replace or should I let the mcharge me like .5-1hr labor to fix it...
Old May 31, 2005 | 07:23 PM
instil's Avatar
ah man,you broke an additional piece too? I still think you should pop that door panel off and check the connector/wires. Maybe theyre just barely making contact. Wont hurt to check,itll take literally 5 minutes. I dont know what clip you broke right now though. I gotta look at mine tomorrow to understand.
Old May 31, 2005 | 07:41 PM
FieldzGood's Avatar
I know that happened to me for a while and when I checked the inside, there was all this gunk and crap where it turns. I cleaned it all out and it popped open wit no hesitation after that
Old May 31, 2005 | 08:09 PM
ornery1's Avatar
wd 40..... works wonders!!!!!!!!!!!!!!
Old Jun 1, 2005 | 02:50 PM
Bondy009's Avatar
DAmn.....Just orderd the part I need, its called an "LOCK ACTUATOR", cost 93 bucks at dealerships and another 85 to install...I flipped em off and ordered it from midway parts...Cost me 70 bucks though.
instil's Avatar
I havent heard my door sqeauk in months since i sprayed a little on the hinges. If only my brakes and window were so quiet
NERDJUSTBNME
Sep 30, 2015 03:20 PM
220k+ A32
Sep 23, 2015 03:38 PM
220k+ A32
18
Sep 22, 2015 11:39 AM
JoshG
51
Sep 21, 2015 10:41 PM
jerrod99_se-l
Sep 16, 2015 02:39 AM
