Cattman/SAFC II dyno graph. with a Baseline graph
Old Jun 10, 2005 | 04:27 AM
  #41
MadMaxNH's Avatar
Fortuna Favet Fortibus
Have fun with it. It makes your car run much better. I would get this over a chip anyday because so far aside from some chip benefits on the autos as far as shifting and rev limit stuff you have more control over the motor with the SAFC and it is adjustable. There may be some benefits I have not heard of by replacing the ECU and finetuning it with the SAFC but I am not interested myself enough to research it.
Old Jun 10, 2005 | 05:15 AM
  #42
Puppetmaster's Avatar
Originally Posted by MadMaxNH
There is a wiring diagram listed somwhere on here. Look for 2k3 wiring diagram post. Or Apexi 2002 Maxima. I found it already before, saved it on another computer, looked (briefly) for you and decided to quit looking because it was killing my buzz. Ask puppetmaster for it, that guy has links up to his ears and deep down it makes him happy to give them to you.
Did ya mean this one?
http://forums.maxima.org/showthread....15#post2806415
Its in the Stickies, in the How-Tos....
Old Jun 11, 2005 | 04:42 AM
  #43
MadMaxNH's Avatar
That would be the one!
Old Jun 11, 2005 | 07:38 AM
  #44
spiromax's Avatar
Seoul Man
MadMaxNH got me to thinking... and now I find myself wanting to ask a noob question... so I think I will.
First of all, I know what the SAFC is and what it does, so I'm not asking for an explanation of how it works or anything. I just want to know if the Technosquare ECU reflash addresses the A/F problems that people are using the SAFC to correct on the stock ECU. I would love to get the SAFC, but I'm also saving for the TS ECU upgrade. If the TS ECU corrects the A/F ratio, then the only reason to get the SAFC would be to have adjustable control over the A/F ratio if you change your car's mods after getting the TS ECU.
Old Jun 11, 2005 | 08:26 AM
  #45
joebangaa's Avatar
i'd only get the Lspec if i bought a TS reflash.....extended redline and modified drive by wire is all i'd want out of it anyway
Old Jun 12, 2005 | 06:38 PM
  #46
MadMaxNH's Avatar
Well the way I looked at it was this. I am told Technosquare asks you to tell them what mods you have on your car and they get the program that their research on a broad array of Maximas said to be the best. The SAFC is custom tuned to YOUR motor. Specific areas that need improvement can be individually adjusted at 12 points in 200 rpm increments. Then you adjust the correction for that rpm point +- 50%. Infinitely adjustable.
Old Jun 12, 2005 | 10:05 PM
  #47
claudiusmaximas's Avatar
well put...
Old Jun 12, 2005 | 10:46 PM
  #48
ChromeSE5's Avatar
hmm so the 5.5 gens as harmonbone stated have sucky a/f ratios... do the 3.0's also suffer from this?
Old Jun 13, 2005 | 10:06 AM
  #49
joebangaa's Avatar
why don't you look at some baseline dynos and find out
Ben2003GLE
31
Jul 17, 2016 08:13 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
CandiMan
Nov 4, 2000 02:24 AM
madmax2k
28
Oct 28, 2000 05:00 AM
Nismo87SE
Oct 23, 2000 08:15 AM
