Uninstall HIDS and Install Halogen...
Old Jun 20, 2005 | 07:21 PM
Jinro's Avatar
Ok, as some of you may know, I am selling my 2002 HID headlights:
http://forums.maxima.org/showthread.php?t=411858
After I sell these lights, I'm going to have to put the original stock halogens.
My question is, how hard is it to put back the original halogen headlights after I remove the hid headlights. So basically, removing hids, and installing halogen.
Do you recommend taking it to a shop or is it a simple a job?
Thanks a bunch.
-Jin
Old Jun 20, 2005 | 08:10 PM
bsetiawan's Avatar
I noticed that you have a 2000 Maxima and you stated that you bought them from the junkyard. If you don't mind me asking, who put them in ? Isn't it just the reverse ?
Old Jun 21, 2005 | 11:47 AM
WeBrake4Nobody's Avatar
Why would you go back to Halogen is my question? If it's because your HID's keep gettin sniped out by hooligans at least get an HID kit for the original headlight housings.
Just my personal opinion....once I turned my '02 Maxima's headlights on for the first time...I knew that was the end of an era for me. The end of the Halogen Era!!
Old Jun 21, 2005 | 11:49 AM
bsetiawan's Avatar
Theft deterrant kit will only cause more damage.
Old Jun 21, 2005 | 03:10 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
maybe he bought the car like that.. but something is not right....here......
If they are not stolen follow the color code of the hal and put them back together
Old Jun 21, 2005 | 06:40 PM
Jinro's Avatar
I guess you guys didn't read the sale section for the headlights.
THE MAXIMA IS NO LONGER MINE. IT IS MY FATHER'S CAR.
I HAVE NO REASON TO HAVE HIDS IF I DO NOT OWN THE CAR ANYMORE.
and for the junkyard question, I just bought them after they were taken off a salvaged maxima. The guy didn't know how to install them. I got them installed at APG autosports in Albany NY, thats where I went to college.
Old Jun 21, 2005 | 06:45 PM
Jinro's Avatar
I am talking about the wiring of the halogens. I remember the guy going through a big mess when he took the halogens out and installed the hids. As I remember, it took him an hour to install it.
So if it's that much work to put it on, i don't think I can just "match up the color" and put it back the original halogens. The guy told me he had to change the electrical wires for the ballast, and now that I'm removing the ballast, I'm not quite sure how to revert it back.
I guess I'll just take it to a shop and have them do it. Thanks anyways.
Old Jun 21, 2005 | 06:59 PM
Lontar1's Avatar
DO you still have the wire harnes for the halogen? If so lookk at the color and put them back together.... that simple...
bsetiawan's Avatar
The wires coming from your original H4 wirings are color coded. Just match those colors and you're good to go. Driver's side and passenger's side have different colors. So you won't go wrong if you match them up properly. Good luck.
Old Jun 21, 2005 | 07:13 PM
Ammi's Avatar
350 Detroit Muscle
It's a simple job. Use your common sense.
Old Jun 22, 2005 | 08:11 AM
MIXXMAX's Avatar
Ummm....It's not quite as simple as one might think. The HID's have a seperate wiring scheme for the high beams since it is one unit, whereas the halogens use two wires for the high beam because it's used in the 2nd filament of the H4 bulb. So, if converting from the HID's to the halogens, another wire must be tapped into the light switch or relay (not sure which one) in order for the high beams to work. I noticed this conversion when I converted from the halogens to the HID's, I had to lose a high beam wire to wire the HID's. The grounding scheme in making the lights come on in the 2K-2K1's are slightly different than the 2K2-2K3's.
Old Jun 22, 2005 | 08:27 AM
Dr. Roy's Avatar
On page 11 of my cardomaine site there is a diagram that shows connection that need be made in order to connnect a 02-03 headlight to the wires on a 00-01 car, its not a writeup, but all the info you need is there
Old Jun 22, 2005 | 09:39 AM
bsetiawan's Avatar
You lose the high beam because you don't know how to wire it up properly.
Old Jun 22, 2005 | 02:47 PM
MIXXMAX's Avatar
Yeah, what I meant was that you lose the LOW BEAM wire from the 2K-2K1 stock harness H4 bulb. You don't need this wire to install the HID's. The high beam wires are used, but wired in a different way. I heard some have the high beams stay on with the low beams (when high beams are turned on), and also have the low beams (HID) flash with the high beam passing signal when the headlamps are in the off position. I have mine wired to flash with the high beams only when headlamps are off. Sorry for the mixup.
Old Jun 22, 2005 | 08:11 PM
Jinro's Avatar
Thank you Dr. Roy and MixxMaxx for knowing what I was talking about.
I'm going to follow your write up on the cardomain.
Thanks Dr. Roy.
MaxLife17
Jun 27, 2019 01:37 PM
Vistance
Sep 17, 2015 05:17 AM
MidnightMaxima_22
Sep 12, 2015 06:02 AM
mpbclutch33
Sep 8, 2015 06:21 PM
MaxLife17
Sep 8, 2015 02:36 PM
