quicky coil question
Old Jun 27, 2005 | 08:13 PM
Klutch's Avatar
I'm pretty sure my 2000 has a bad coil and I think it is in the rear since the fronts were replaced recently. I was just going to order one and try it down the line until my rough idle goes away. Do all 3 of the rear coils used the same part? Like I said, i'd like to just by one and try it on each plug until I narrow it down.
Also, the parts are referred to LH and RH. Which are the rear? RH?
Old Jun 27, 2005 | 09:01 PM
Klutch's Avatar
And just in case I'm affected by the fuel cut off problem is there a way to check my ECM to determine what version I have? The guy I bought the car from said they did an ECU flash for the other coils and the MAF. I only assume it doesn't have a seperate piece that needs to be flashed just for the fuel cut off problem. Is there a proceedure I can do to find out what version the ECU is currently running at?
PH98I30
20
Mar 25, 2020 03:44 PM
gustavison
Oct 4, 2015 06:50 PM
jerrod99_se-l
Sep 23, 2015 10:29 AM
pears
Sep 18, 2015 05:25 AM
Johnny9595
Sep 3, 2015 05:18 AM
