how to turn off airbag light?
Old Jun 27, 2005 | 11:33 PM
okay's Avatar
I recently took out my in cabin filter to clean it and i had to unplug the airbag sensor to get my filter out. I read the housecor instructions that said not to unplug it but the wire was getting in the way so I did it anyway, now my airbag light is blinking. I searched and found this http://forums.maxima.org/showpost.ph...&postcount=100 link but its not working. Can anybody help me with this?
Thanks.
Old Jun 28, 2005 | 01:06 AM
instil's Avatar
im not an autority on it, but did you have the battery disconnected when you did this? lucky the airbag didnt blow up in your face! If you havent already, reconnect the airbag connector, and let your whip sit for an hour or two with the battery disconnected,see if that makes it go away.
I just did the same thing to my filter this weekend, but made sure not to unplug that wire....it was even close to being in my way though. My biggest issue was when i put everything back together, the metal piece inside the glovebox, that the glovebox 'door' latches onto, had a small metal clip attatched to it,and dont no where it goes. It seems to open and close and stay latched without it though,so i dunno
Old Jun 28, 2005 | 06:45 AM
Ammi's Avatar
350 Detroit Muscle
disconnecting the battery won't work. I tried that already
Old Jun 28, 2005 | 06:54 AM
Ammi's Avatar
350 Detroit Muscle
here's what I've found for 2002-2003 Maximas
Originally Posted by studman
If your airbag light is on (or flashing)... try this. By the way, use a stopwatch to count.... the timing must be accurate in order for it to work.
1) Turn IGNITION on (but don't start car)
2) After the AIR BAG warning lamp lights for 7 seconds, turn IGNITION off within 1 second.
3) Wait 4 seconds
4) Turn IGNITION on (but don't start car)
5) After the AIR BAG warning lamp lights for 7 seconds, turn IGNITION off within 1 second.
6) Wait 4 seconds
7) Turn IGNITION on (but don't start car)
8) After the AIR BAG warning lamp lights for 7 seconds, turn IGNITION off within 1 second.
9) Wait 4 seconds
10) Turn IGNITION on (but don't start car)
11) Wait 3 seconds
12) Turn IGNITION off
13) Wait 2 seconds
14) START Car (the light may be blinking slower than before)
15) Wait 3 seconds
16) Turn IGNITION off
17) Wait 3 seconds
18) START Car
The light should be gone unless the problem remains. Try it again if it fails. If it still remains on, you'll need to visit a dealer to have the problem looked at.
Old Jun 28, 2005 | 07:11 AM
Ammi's Avatar
350 Detroit Muscle
Another technique from STUDMAN. Procedure is little different.
Note: Timing is KEY, use a stopwatch if you have to.
2) After the AIRBAG warning lamp lights for 7 seconds and then goes out, turn IGNITION off within 1 second.
3) Wait 4 seconds
5) After the AIRBAG warning lamp lights for 7 seconds and then goes out, turn IGNITION off within 1 second.
6) Wait 4 seconds
8) After the AIRBAG warning lamp lights for 7 seconds and then goes out, turn IGNITION off within 1 second.
9) Wait 4 seconds
11) Wait 3 seconds
13) Wait 2 seconds
14) START Car
15) Turn IGNITION off
16) Wait 2 seconds
17) START Car
AIRBAG warning lamp should blink for 7 seconds and then go out and never come back on. If it does, then you have a problem.
Old Jun 28, 2005 | 07:37 AM
instil's Avatar
is that russell crowe in your avatar dude? lolol i always forget to ask you
Old Jun 28, 2005 | 09:29 AM
Bondy009's Avatar
yes, from master and commander movie.... Anyone know how to get rid of the seatbelt light? Without taking the actual bulb out of dash...Is there a wire i can cut or a fuse to remove. Thanks guys....I buckle up but i make a lot of frequent stops ad have to wait...So i take the thing off and it bugs me...Anyway, any help would be appreciated.
Old Jun 28, 2005 | 09:55 AM
instil's Avatar
i bet if you take apart the piece the buckle goes into, you'll be able to find a little button or sum'n that you can disable or tape down so it thinks your buckled in. I assume you dont want to jam something in there for good,cause you wont be able to use your seatbelt.
Old Jun 28, 2005 | 10:29 AM
shurik's Avatar
3) Wait 4 seconds
6) Wait 4 seconds
9) Wait 4 seconds
11) Wait 3 seconds
13) Wait 2 seconds
14) START Car
16) Wait 2 seconds
17) START Car
Did that procedure worked on anybodies car? Did anyone tried doing it?
Old Jun 28, 2005 | 11:38 AM
Ammi's Avatar
350 Detroit Muscle
It worked for my 01. It should work for 2000-2003
Old Jun 28, 2005 | 12:49 PM
okay's Avatar
3) Wait 4 seconds
6) Wait 4 seconds
9) Wait 4 seconds
11) Wait 3 seconds
13) Wait 2 seconds
14) START Car
16) Wait 2 seconds
17) START Car
when you wait for the airbag light to go on is it when it first starts to blink? or when it first comes on? because when i first turn my ignition on everything is lit then after about 3 seconds the airbag light starts to blink. at what point do you start counting?
Old Jun 28, 2005 | 01:10 PM
Ammi's Avatar
350 Detroit Muscle
you start to count as soon as you turn your key.
Old Jun 28, 2005 | 07:38 PM
okay's Avatar
nice!! thanks it worked.
instead of counting to 7 i just waited for the airbag light to start blinking on the first blink i just shut off the ignition and counted 4 seconds and continued with the directions. that seemed to be more accurate than counting with a stop watch.
thanks for the help.
tsi6001
Oct 3, 2022 10:23 PM
ThomasofSodor
Mar 22, 2018 08:18 PM
Flores94
Aug 13, 2015 01:17 PM
kirkhilles
Aug 8, 2015 10:53 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
