Helpppp!!!!!!!!
Old Jul 1, 2005 | 07:53 AM
qnpark8282's Avatar
Helpppp!!!!!!!!
Just installed headers on a 2002 maxima and its throwing a lean in bank 1 code. Is this normal code after headers install. Still have stock catt in there.
Old Jul 1, 2005 | 08:19 AM
JUICED's Avatar
Did you change the gaskets? Check for leaks!
Old Jul 1, 2005 | 01:10 PM
qnpark8282's Avatar
yes i used brand new nissan gaskets. retightened all bolts after 50miles.
Old Jul 1, 2005 | 08:05 PM
qnpark8282's Avatar
someone? help?
Old Jul 1, 2005 | 11:54 PM
E55AMG2's Avatar
Wat
What brand? and did you get a new exhaust seal for the main cat
Old Jul 2, 2005 | 08:03 PM
geenowalker's Avatar
Any chance that you are killing the MAF. The headers may be pulling more flow, which your computer may perceive as a need for more injection. Lean bank was what I had when the MAF went. Did you re-program the ECU for your headers.
Old Jul 3, 2005 | 08:21 AM
qnpark8282's Avatar
i dont believe we can reprogram our ecu. I do have advance timing done to my car from nissan. all the seals are new. Stillen headers.
Old Jul 3, 2005 | 10:15 AM
E55AMG2's Avatar
Wat
There is your problem....stillen headers dont make any power to begin with. Also, you have to use O2 sensor simulators with their kit...they should have been included.
Old Jul 3, 2005 | 12:08 PM
upstatemax's Avatar
not to hijack the thread...
I just installed the HS headers on 00' and I can hear a leak... It has been pissing me off finding it. Only because you can only hear it when the car is under a load (car is in gear). if the car is in park and you rev the engine you get nothing.
I have narrowed it down to a couple things... the top of the list is the gasket between the Y-Pipe and Cat. That is the only non-metal gasket on the exhaust, could that be the leak???
If not It might be the rear manifold, and I hope it is not that because then I have to pull the upper intake to really get at the bolts.
Old Jul 3, 2005 | 09:26 PM
qnpark8282's Avatar
i give up on this damn thing
Old Jul 3, 2005 | 11:44 PM
E55AMG2's Avatar
Wat
you should be using gaskets with a metal ring...not a full metal gasket or hello leaks
Old Jul 3, 2005 | 11:45 PM
E55AMG2's Avatar
Wat
go buy yourself a set of HS or cattmans....you will love your car once again
Old Jul 3, 2005 | 11:49 PM
steven88's Avatar
Need A Light?
Have you tried resetting the ecu and driving it around? you never mentioned anything like that so I assume you haven't? Go try that out first....
Old Jul 4, 2005 | 05:31 AM
qnpark8282's Avatar
i resetted the ecu million times cause the code keeps popping up. i replace all the exhaust gaskets yesterday working till 4am. resetted the ecu for the 10th time. Also order o2 sensor simulators for 2 for 90 bucks. hopefully everything will be solved.
Old Jul 4, 2005 | 03:31 PM
upstatemax's Avatar
I was going to get the OEM Nissan ones.
Old Jul 4, 2005 | 03:45 PM
Fezzik's Avatar
I'm going to get a SAFC because my car started running a lot leaner after i installed the headers. I did a dyno a few weeks after the headers and its obviously lean at the lower rpms.
Old Jul 4, 2005 | 08:39 PM
E55AMG2's Avatar
Wat
they are too small, internal diameter wise...
Old Jul 5, 2005 | 12:09 AM
steven88's Avatar
Need A Light?
how lean are you running?
Old Jul 6, 2005 | 08:27 PM
qnpark8282's Avatar
code is still here and its driving me insane. Do you guys think its worth getting the car dynoed?
Old Jul 6, 2005 | 09:06 PM
traderfjp's Avatar
The 02 simulators will hopefully solve your problem. What is your butt dyno telling you about your Stillen headers? Do you have any other exhaust MODS?
Old Jul 6, 2005 | 09:56 PM
E55AMG2's Avatar
Wat
dont even bother dynoing the stillen headers...its about 1whp better than a Y, B, rear section on a 5.5 gen. We proved that 2.5 yrs ago. As for your code...I explained it already, its not going anywhere w/o O2 sims. If you still have it with the sims, replace the sensor. However, its my recommendation that you get rid of that whole setup ASAP and get a decent set of headers.
xloki77x
Oct 26, 2007 07:39 AM
flthere
18
Sep 7, 2007 11:37 AM
exit10
Nov 15, 2004 08:16 PM
AuToMaX_95
Mar 26, 2003 09:29 PM
flynlr
Mar 9, 2003 02:29 AM
