DIY for 02 SE Radiator Fluid flush
http://www.motorvate.ca/mvp.php/502
This is for a 4th Gen but I followed the same steps when I did it for my '02, except that
1) I drain and fill the radiator with just distilled water several times (~6 times) - capacity for the radiator is about 4 qts
2) the last time, drained and filled the radiator with straight full-strenght NISSAN (green) long life coolant, which would make for almost a 50/50 mix left in the system
anybody run a mixture other than 50/50? I currently run 50/50 but might change to 80 water and 20 coolant in the future....some might say 20% coolant is overkill, but I read somewhere that coolant is mainly there to protect it from rusting?
Check the fluids and lubricants forum for more info.
06-06-2017 02:01 PM
Unclejunebug
04-02-2016 05:42 AM
Need help
23
10-02-2015 08:56 AM
