Headlight Bulb Replacement
Old Jul 11, 2005 | 11:38 AM
Bones45's Avatar
I looked in the stickies, but didnt see anything regarding this.
Has anyone replaced a headlight bulb in a 01, SE?
not the entire headlight/assembly, rather just the $20 bulb. My left is out...brights are out as well.
It would seem to be a fairly easy process..does anyone have any info on it?
Old Jul 11, 2005 | 12:59 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
pull the electrical connector out the back of the bulb. then pull the rubber shell/gasket in the same direction as you pulled the connector (it should have a tab you can get grip on. you will then see two metal braces that actually surround the bulb. put one finger around each side and squeeze them towards each other. the brace will fall backwards and you should be able to pull the bulb out. follow reverse to reinstall. also a regular oem replacement bulb should not be 20 bucks unless you bought some kind of tinted bulb or premium brand from the dealer.
Old Jul 11, 2005 | 05:16 PM
cobalt416's Avatar
check this site out, i never bought from them myself, but i might if my bulbs were out...
http://www.autolamps-online.com/halogen/index.htm
Old Jul 11, 2005 | 05:29 PM
Ammi's Avatar
350 Detroit Muscle
You do have an owner's manual don't you?
Old Jul 12, 2005 | 05:26 AM
Bones45's Avatar
every car I have ever had, "changing headlight bulbs" is not in the manual.
Old Jul 12, 2005 | 05:31 AM
jimmycapp's Avatar
You've owned more than one car? and don't know how to change a bulb?
Old Jul 12, 2005 | 05:36 AM
Progress's Avatar
It's business time.
I've bought from them. I also have the Power2Night bulbs, they are probably the best halogens I've had. Power2Night > Silverstars or the like. IMO
Old Jul 12, 2005 | 06:38 AM
Bones45's Avatar
If you read my initial post, and clearly either you didn't, or just didnt comprehend it, you will see that Im not saying I dont know how to do it.
Im asking if anyone has done it and have information on it. Maybe there are some nuances about it which would help me out.
If you arent sure what nuance means,
www.dictionary.com
Old Jul 12, 2005 | 06:54 AM
jimmycapp's Avatar
The only way this thread could be more useless is if you had a poll on who had changed a headlight bulb. Give me a break. Pop your hood and take a look. I promise that someone one with your obviously superior education could figure it out.
good luck
Old Jul 12, 2005 | 07:46 AM
Progress's Avatar
It's business time.
www.dictionary.com
Nope, no nuances. Pretty self-explanatory. You may want to disconnect the battery but even that isn't necessary. Make sure to not touch the bulb to your skin as you probably know and avoid colliding it on anything to prolong life.
GL
KristyKarina
Aug 23, 2015 09:53 AM
YourLocalAsian
Aug 17, 2015 02:33 PM
MikesChevelle
Aug 6, 2015 11:36 AM
