Tranny Fluid Change = BIG difference
Old Jul 12, 2005 | 12:26 AM
meccanoble's Avatar
Sports Button FTW
finally grew enough ***** to do this on my own. Very easy job, common tools needed, I would say a 30 minute job for a newb if all parts are together and ready to be used. Longest part is refilling the tranny.
I have an 01 max 5 speed which is shy of 67k miles and the fluid was DARK BROWN, i mean on some sewage sh*t. I changed the fluid with the recommended Redline ATF 90 blah blah blah and i can feel the change. Shifting is a lot smoother, goes into gears a lot easier and the feel is so much better. This is one of those mods that are not only recommended for maintenance but driving comfort as well.
Special thanks to Kevlo for AIM help
Old Jul 12, 2005 | 03:59 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
You use ATF on a 5 speed?
Old Jul 12, 2005 | 07:32 AM
JaredMaxSE's Avatar
He did the right thing. Majority of manual cars these days still use ATF fluid. Definatly a good idea to flush it every 60K miles. Makes a huge difference and helps keep the tranny in good shape.
Old Jul 12, 2005 | 07:35 AM
2kayznmaxima's Avatar
nice, now ur gonna help me with mine rite?
Old Jul 12, 2005 | 07:41 AM
meccanoble's Avatar
Sports Button FTW
no doubt if its the same as the 5 speed, it should be a piece of cake
Old Jul 12, 2005 | 07:44 AM
Kevlo911's Avatar
Kevlo for President
Lol, no ATF. I got him to buy MT90
Old Jul 12, 2005 | 12:35 PM
boondoxmax's Avatar
I am gonna be doing this on my 6 speed. The notchy feel really sucks and most people on the org says redline syn. will cure the problem
Old Jul 12, 2005 | 02:18 PM
itdood's Avatar
I've run MT90 for over 120k miles in a different car. Good stuff but it's not as slick as other fluids, that's why it improves shifts. It makes the synchros slow down faster and so the trans shifts better.
The down side is that it's not so great for bearings and gears.
I let the drain interval go a bit too long once and I started to hear the bearings howl. Once I changed the oil they quieted back down. There was also a lot of metal in the fluid when I drained it.
Just make sure you shorten your drain interval with the Redline MT90, it doesn't hold up as well as stock fluid IMHO.
Old Jul 12, 2005 | 08:19 PM
bugbite77's Avatar
should this tranny fluid change be done on an automatic tranny aswell, ive got 51K and idk if its safe to do it?
Old Jul 12, 2005 | 08:32 PM
n3985's Avatar
大陆弟弟
Shouldn't tranny fluid be changed every 30k?
Old Jul 12, 2005 | 08:33 PM
instil's Avatar
imma do mine this week possibly. if i dont haver any problems with it (which i dont think i will), I'm sure you'll be fine. the writeup was pretty straight forward
Old Jul 12, 2005 | 08:38 PM
instil's Avatar
yea it should be done on automatics too. im at 52k so me and you are overdue.
Old Jul 13, 2005 | 11:39 AM
jessefrank's Avatar
I just changed my Auto fluid in my 03 with M1 Synthetic @ 36,000 miles. I will def. change my fluid every 30k. I did the flush and pan drop. The fluid seemed fine, but was noticable darker than the new stuff (almost black when compared in a cear jug). The magnets in the pan were full of metal shavings (they looked 2-3 times their real thickness). I didn't expect to see so many shavings. I also cleaned the screen (there were some metal shavings on the screen; not bad, but a few) Also there was some sludgey residue with very,very small metal flakes in it on the bottom of the pan. I used some brake parts cleaner to clean everything. I haven't noticed any improvements in shifts, but I had my seloniods replaced under warranty a few days after the flush and the shifts changed with that. I expect to notice a differnce when the weather gets colder.
Ray229Harris
Sep 16, 2015 08:16 PM
homeyclaus
Sep 3, 2015 06:15 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
RealityCheck
Aug 5, 2015 06:18 AM
