HomeDepot: PCV Blowby Oil Catch Reservoir
Old Aug 30, 2005 | 11:15 AM
  #41
98SEBlackMax's Avatar
Maxima.org Insomniac
Originally Posted by Kevlo911
Man I think my filter is fcked up. The oil level doesnt seem like it rises anymore.
Kevlo check the PCV valve and make sure it's not clogged. My air line catch can stopped filling up for a while and when I went to service the DEK manifold last week the PCV valve was clogged. Now that I have a good PCV valve on it, it's slowly filling up again. I think our setup prematurely causes PCV valves to clog up faster than normal, something to consider I guess.
Old Aug 30, 2005 | 11:42 AM
  #42
igzy's Avatar
I Know Kwaliti
Originally Posted by MAXGXE
I think this was asked but maybe I missed the reply air compressor???? what is this and can it be seen from pics and is there any wiring involved? by the way I know what an actual air compressor is.
That was a joke. No air compressor is used in this set up. Only oil separator is used. These oil separators are used on compressed air lines to remove moisture from it, hence the air compressor joke...
Old Aug 30, 2005 | 12:19 PM
  #43
DrKlop's Avatar
Driving is the next best thing
I don’t understand this, say you make and install this oil catch reservoir. What do you need it for anyways, just to collect oil?
Old Aug 30, 2005 | 12:28 PM
  #44
MAXGXE's Avatar
Compressor
oh thanks for the reply just went over my head
Old Aug 30, 2005 | 12:31 PM
  #45
Larrio's Avatar
The Definitive AE Master
yes, to collect oil so it doesn't reach your intake manifold to gunk things up or mix up with your fuel
nice mod irish, definitely something to consider. thanks
Old Aug 30, 2005 | 12:39 PM
  #46
DrKlop's Avatar
So, basically, it increases hp and torque?
Old Aug 30, 2005 | 12:52 PM
  #47
djfrestyl's Avatar
Suspension Yoda
No man, it just keeps your intake from being gunking up.
Old Aug 30, 2005 | 01:38 PM
  #48
steven88's Avatar
Need A Light?
u wont get increased hp+tq...but u might re-gain lost HP....when the oil mixes with the fuel, it reduces octane...and when it does, it could allow the engine to ping...timing is pulled back and so is HP...if u install this catch can, oil will not get mixed with fuel therefore u won't ping, therefore timing won't get pulled back...and there comes back your lost HP when u originally didn't have the catch can
Old Dec 3, 2005 | 12:44 AM
  #49
the_3d_man's Avatar
yes... +30HP!! and you can have it for only $29.99!!
oh... this isn't ebay... heheh
Old Dec 17, 2005 | 08:09 PM
  #50
Gary Libretti's Avatar
Just completed my version of this mod. Pretty much followed Irish's idea...Home Depot for parts. I re-used the OEM hose and screwed the filter into the metal shelf under that plastic cover.
Old Dec 17, 2005 | 08:47 PM
  #51
DrKlop's Avatar
Looks nice and neat!
I got a question to you guys, what if I disconnect this hose and let the oil drip under the car, will it do the same thing?
Old Dec 18, 2005 | 03:00 PM
  #52
Pri63's Avatar
Irish - went to Homedepot today and tried to find the oil reservoir...can you tell me what the exact part is called? Thanks.
Old Dec 18, 2005 | 04:47 PM
  #53
RA030726's Avatar
I'm nutty for Nissans
take out the filter and catch more oil
Old Dec 19, 2005 | 06:48 AM
  #54
reMaxxxK's Avatar
Husky air compressor filter, should loacat at where sell tools and parts
Old Dec 19, 2005 | 07:59 AM
  #55
Iron Scimitar's Avatar
Tha Snatcher
The silver fittings highlighted, what are they called? Do they come w/ the reservoir?
Old Dec 19, 2005 | 08:15 AM
  #56
Tha Snatcher
http://www.homedepot.com/prel80/HDUS...dd&source0=POP
here you go bro. that should help.
Old Dec 19, 2005 | 03:04 PM
  #57
irish44j's Avatar
retired moderator
no, they're standard air hose fittings, threaded into the reservoir....they should be hanging nearby in the air compressor section.
Old Dec 19, 2005 | 04:30 PM
  #58
eng92's Avatar
Brass plumbing fittings may also be used. 3/8" hose barb - 3/8" MNPT.
Old Dec 19, 2005 | 05:35 PM
  #59
Tha Snatcher
found'em 1/4'' T Thanks Josh.
Old Dec 19, 2005 | 05:51 PM
  #60
DrKlop's Avatar
I don’t mean to be too persistent, but could anyone answer this question please:
Old Dec 19, 2005 | 06:28 PM
  #61
irish44j's Avatar
retired moderator
well, if you like oil being sprayed all over the place. At WOT, it's not a "drip"...it's a "spray" of oil....
Old Dec 19, 2005 | 08:28 PM
  #62
reMaxxxK's Avatar
3/8" or 7/16"? do u guys use the old hose and cut it short, if new hose was connect to PCV, what size are the balb fitting?
Old Dec 20, 2005 | 04:15 AM
  #63
Tha Snatcher
About 3' of 7/16 hose. Irish posted that in the first post. I'd get new hose, just to have new components when doing a mod.
Old Dec 20, 2005 | 05:23 AM
  #64
gateway_sc's Avatar
Maybe I'm missing it, but both hoses need to be connected to their original location--one to the PCV, the other to the vacuum source. If you disconnect one of the hoses (presumably the vacuum side) to drain the oil, you'll induce a vacuum leak, but that could be plugged I guess. And like Irish said, it would make a mess.
I'm just curious how long it takes to fill up the reservior.
I've tried this mod on my SC* and I had to drain it too often for my liking. Maybe boosted applications just blow more oil.
*Thunderbird SC: the other end of the PCV connects to the supercharger outlet tubing and the oil usually collects in the IC.
Old Dec 20, 2005 | 08:10 AM
  #65
kcowden's Avatar
Here is a pic of my set up. I've had it on for a month or so now and they seem to fill up pretty quick that's why I added another resivoir. Thinking about getting the BIG resivoir from Home Depot.
Old Dec 20, 2005 | 11:58 AM
  #66
bladerunr's Avatar
Does anyone have an official write-up for the 02-03? thx
Old Dec 20, 2005 | 12:03 PM
  #67
Tha Snatcher
There's a thread for the 3.5L.
Old Dec 21, 2005 | 09:07 AM
  #68
NJ Devils Fan's Avatar
That green tubing is pretty phat, I would want to do this mod if I could see someone else do it forst, maybe like a video or something.
Old Dec 21, 2005 | 12:10 PM
  #69
kcowden's Avatar
Thanks.... it's left over from when I installed a water softener in my home. I figured what the heck, it's worked out and gave me a chance to see just how much oil is really "blowing by". There was still oil going back into the manifold with the one resivoir so I added another and it seems to catch all of it now.
It's really easy, there are a few how to's here. Just follow them and you'll be fine. You've always got the org to help you out if you get in a jam.
Old Dec 21, 2005 | 02:02 PM
  #70
95maxrider's Avatar
Lightly modded
I put mine in a week ago or so and it's filling up fast!
Old Dec 21, 2005 | 04:10 PM
  #71
doc2278's Avatar
Doctor D I presume???
save yourselves the fustration and buy a universal oil catch canister from weapon R. Idon't believe it comes with the 3/8 or 7/16 inch hosae and adaptors you would have to contact weapon R themselves
Old Dec 21, 2005 | 04:12 PM
  #72
doc2278's Avatar
I guess if it works then.............
Old Dec 21, 2005 | 06:15 PM
  #73
weltonw's Avatar
So kcowden, has your setup eliminated (to your satisfaction) any pinging you were experiencing?
Old Dec 21, 2005 | 08:00 PM
  #74
Anyone have any links for the 3.5?
Old Dec 21, 2005 | 11:39 PM
  #75
danger300z's Avatar
guys i just pick my up at autozone, just incase some of you hate making those long lines at "homesdepot"
Old Dec 22, 2005 | 07:14 AM
  #76
kcowden's Avatar
Yes, once you see the amount of oil that is just being poured back into the intake manifold you will understand why carbon build up, which is one cause of pinging, is such a problem with our engines. I feel that in order to eliminate/reduce the amount of pinging in our cars that you have to implement some or all of the possible solutions discussed here. There are numerous threads on this topic, I'm sure Puppetmaster can provide a few since he is the "master of teh search" Anyway, as much as our cars are the same they are all different. We live, drive, get gas, communte, treat our cars differently, so trying to figure out what may work for one may not work for another. Sorry for the long winded response but this was the easiest way to say it. Good luck
Old Dec 22, 2005 | 10:25 AM
  #77
808SE's Avatar
Aside from the synthetics eating through some of the catch cans, is there a reason that people aren't just dumping the caught oil back into their crankcases? Am I missing something? How are you all disposing of the oil?
Old Dec 22, 2005 | 11:13 AM
  #78
Tha Snatcher
damn, didn't think of that...
Old Dec 22, 2005 | 11:52 AM
  #79
spirilis's Avatar
Probably because it's soaked in gasoline and is probably nasty. I'd rather dump it and put fresh oil back in to compensate.
Old Dec 22, 2005 | 01:08 PM
  #80
2002 Maxima SE's Avatar
Check out my updated post on the ebay catch can:
http://forums.maxima.org/showpost.ph...&postcount=174
If you buy one, pay the money and get a good one. Lesson learned.
