HomeDepot: PCV Blowby Oil Catch Reservoir
Old Dec 22, 2005 | 05:50 PM
  #81
Iron Scimitar's Avatar
Tha Snatcher
Originally Posted by 2002 Maxima SE
Check out my updated post on the ebay catch can:
http://forums.maxima.org/showpost.ph...&postcount=174
If you buy one, pay the money and get a good one. Lesson learned.
ATTENTION
I'm withdrawing my support for this ebay catch can. I installed mine this past summer, took it off today to see how much oil was collected and found it bone dry. There was a thin layer of oil on the inside walls, but none collected. The tubes got darker and darker so I assume it was still getting through. If you do this mod, stick to the oil/water separator or some catch can with a baffle. This one just has two holes in the top. The input is sucked right back out of the output.
Man that majorly sucks.
Old Dec 22, 2005 | 09:10 PM
  #82
reMaxxxK's Avatar
thanks 2002 maxima se for the update, my friend just want to buy of this and me are using the home depot one. for those people especially Irish use synthethic oil, don't worry, read the instruction paper come with package, you can buy some metal can, replacement filter, holding bracket etc etc by calling 800-543-6400,
but one thing that bordering me is the filter inside of it, what about it get clog, had read another thread about this subject that some people remove the filter and said it would catch more oil and it won't suck it back to intake manifold, it that confirm work????? I just don't want the oil get back in there, period.
Old Dec 23, 2005 | 06:37 AM
  #83
igzy's Avatar
I Know Kwaliti
Yes, at first I had the filter in and it was collecting oil but not at any breath taking rate. Then I removed it, noted it was soaked, and put the canister back without the filter and for same period of time now I collect 2-3 times more oil than previously with the filter in... And I just dump it thought it is $10/qt Mobil1...
Old Dec 23, 2005 | 06:38 AM
  #84
kcowden's Avatar
Originally Posted by spirilis
Probably because it's soaked in gasoline and is probably nasty. I'd rather dump it and put fresh oil back in to compensate.
... it has a strong smell of gasoline/oil. Makes you fingers stink bad too....
Old Dec 25, 2005 | 10:34 AM
  #85
doc2278's Avatar
Doctor D I presume???
That's what I was saying about the weapon R universal catch tank. Buy from someone who has already put development into their product. Weapon R's number is 1-650-877-8280 it already comes with fittings and such. it is made of 6061 billet aluminum. they also have aluminum catch tanks with fittings already welded in. It might be possible they would custom-make you one. If you show off your mods at shows and meets it just makes sense to use parts that were made for the job. why make it 2nd rate? yeah it'll cost a little more, but it's worth it!!!! that's for sure.
http://www.weapon-r.com
You might be able to custom fit one of these they say they are car specific. Just might work though. Call'em if you got questions.
http://www.weapon-r.com/store/agora....&ppinc=search2
Old Dec 25, 2005 | 10:46 AM
  #86
igzy's Avatar
I Know Kwaliti
Sounds like you are their promoter Besides, I (and I'm sure most guys here) take pride in making my own mods and improvements
Old Dec 25, 2005 | 11:06 AM
  #87
danger300z's Avatar
thats very true . Im shock to see how much oil was going on the manifold
Old Dec 25, 2005 | 04:04 PM
  #88
doc2278's Avatar
Just to clarify I do not promote for them I own my own company, Don't get me wrong I'm not knocking what you guys are doing.Should take pride in it.
but isn't this forum about giving information that might be helpful in making your car better? That's all. If you don't like the info i give; you don't have to use it. I can live with that.
Old Dec 25, 2005 | 08:07 PM
  #89
igzy's Avatar
I Know Kwaliti
Doc2278, no prob, we all know that you can buy one of these canisters and all the necessary hardware as a kit that many companies offer just like HID lights, and many other parts we all try to home-make; however, as the thread title says, this is how you make your own using HomeDepot parts or any other means to make the same thing but yourself which gives me and many others a feeling of creativity and ingenuity
Old Dec 25, 2005 | 08:31 PM
  #90
irish44j's Avatar
retired moderator
I hardly think Weapon R has put any "development" into the product. Oil catch cans (with and without baffles) have been around LONG before "Weapon R" ever existed...it's a VERY simple concept. Their cans are just like 100 other ones on the market, in truth. Maybe they look nicer, or have a shiny finish, but they all work on the same principles of seperating the liquid from the air....
That said, the "purpose-made" catch cans obviously offer an advantage when it comes to capacity and materials - but many of us balk at paying $50-100 for something that truthfully costs about $2 for these companies to make. Hence the "Home Depot" catch can idea, which works just as well, but simply requires that it be emptied a bit more often.
The BEST solution would be to have a larger reservoir that could screw onto the HD oil seperator top....basically a larger can with a threaded top. But that's a project for another day
Old Dec 25, 2005 | 11:12 PM
  #91
konak85's Avatar
Lowes rules!!!!
Old Dec 26, 2005 | 06:51 AM
  #92
doc2278's Avatar
Thank you Irish I definitely can appreciate your knowledge base. It is obvious you know more about this than I do.
I know husky makes a larger canister with a half turn bleeder valve on the bottom for 19.95 at the depot. It accepts a 3/8'' fitting. I only know this because I use these at the office for my air lines.the bottom part of the canister screws on. They are black canisters if that helps you guys find them.
Old Dec 26, 2005 | 06:56 AM
  #93
doc2278's Avatar
Very true Igzy I see your point as well as Irshs' point. I guess i got
LOL
Old Dec 26, 2005 | 03:37 PM
  #94
irish44j's Avatar
retired moderator
I've been meaning to get the bigger canister, but HD and Lowes always seem to be out of stock of the 3/8" fittings and the 1/4" reducer's I'd need!
that, and I'm working on other projects and too lazy to mess with this one anymore
Old Dec 26, 2005 | 04:58 PM
  #95
doc2278's Avatar
well just in case you mightchange your mind on the lazy part, LOL you might find the reducers thru a company called Mcmaster Carr they are located in NJ . I can get you the info tomorrow.Or for whoever else is interested.
Old Dec 26, 2005 | 05:19 PM
  #96
irish44j's Avatar
retired moderator
I'll have to look into that, thanks! I'm sure Sears has stuff like that too, if I bothered to look.
Old Dec 27, 2005 | 02:35 PM
  #97
doc2278's Avatar
Research done....... http://www.mcmaster.com
Part # 9171K216
* this is what they told me would work*
retails for $3.49
Description: Hex center nipples 3/8 to 1/4
Max pressure: 4000 psi
phone # 732-329-3200
Check this out see if it will work for you guys
Good luck
Old Dec 27, 2005 | 07:13 PM
  #98
Edward Lee's Avatar
2000 Maxima SE Oil Catch Reservior
Alright, I followerd the pack and did the oil catch reservior. Just wanted to post a few pics so orgers can see the install and reservior location.
http://www.cardomain.com/ride/584060/6
Old Jan 1, 2006 | 04:01 AM
  #99
the paragon's Avatar
can't seem to find the 7/16 fuel line hoses mentioned. Autozone seems to have ran out. any other options?
Old Jan 1, 2006 | 10:38 AM
  #100
Edward Lee's Avatar
Keep looking and if you have a 2000 like me, I think that you should be looking for 3/8" not 7/16 as the thread says. I tried both and the 3/8 fit much better. There is no need to use hose clamps with 3/8" hose.
Post a pic when you finish.
Old Jan 1, 2006 | 02:14 PM
  #101
Thanks Edward! I will definetly post pics once i'm done.
Old Jan 10, 2006 | 10:49 AM
  #102
igzy's Avatar
I Know Kwaliti
I used 3/8" hose on my 2K too...
Just a word of caution: make sure your set up is tight and there are no air leaks in it. Verify everything including the fitings (use some teflon tape on threads), canister drain, the base of canister, clamps and connections...
I had a small leak between the canister cup and the metal base at the round rubber gasket that as a result was throwing an oxygen sensor code P0140...
Old Jan 10, 2006 | 11:53 AM
  #103
Edward Lee's Avatar
No teflon tape here, no hose clamps either. Just a tight fit all the way around w/no leaks.
[IMG][/IMG]
Old Jan 14, 2006 | 09:32 PM
  #104
spdfreak's Avatar
Instructions?
Do you have step by step instructions?
Old Jan 14, 2006 | 09:39 PM
  #105
igzy's Avatar
I Know Kwaliti
For .....?
Old Jan 15, 2006 | 03:03 AM
  #106
01maxima4u's Avatar
i've seen this on a few forums. looks good.
Old Jan 15, 2006 | 05:50 AM
  #107
spdfreak's Avatar
For .....?
For the installation.
Old Jan 15, 2006 | 07:39 AM
  #108
jdmaxima89's Avatar
On the pedobear bandwagon
I would kinda like to see step by step also... I'm kinda special when it comes to this stuff.... like where exactly are the two places that we'd be connecting the hoses to in the engine... with some pics. I have a 2000... I am only to assume that when you are saying 3/8, you mean inside diameter of the hose. And will anything be hurt by using nylon fittings instead of brass?
Old Jan 15, 2006 | 09:23 AM
  #109
Edward Lee's Avatar
INSTRUCTIONS FOR OIL CATCH CAN:
Alright, first go get all the parts either at Home Depot or Sears. By the way, Sears sells a larger reservoir so it's probably your better bet. Don't use plastic for the connections. They sell brass connectors where they sell the reservior so you shouldn't have any problems in getting some 1/4 to 3/8 fittings. Don't get the quick connects like everyone else gets. They're not the right connections. Get the ones for hoses. They look like a shell or an animals horn (cone shaped).
I/D of the hose is 3/8". Get enough in case you make a mistake and make sure that it is good for fuel. No need for fuel injection line, just get the regular fuel line, it's much cheaper.
The rest is pretty straight forward. Look and see where my reservior connects at the top of the manifold. All you do is disconnect that part of the hose and follow it to its other end. Don't disconnect the the other end, instead use the attached hose to help you pull off the PCV valve. Just give it a nice tug and it should pop off. A slight twisting action may help.
Installation is the reverse of removal. I got that line from Haynes Manuals.
Good Luck! Post if you need anymore help.
Old Jan 15, 2006 | 10:03 AM
  #110
jdmaxima89's Avatar
Having problems finding that reservoir on the sears website. Do you have a part number or link so I can see it... I'm 30 miles from the nearest Sears or Home Depot... so I like to go in knowing exactly what I need. Thank you.
Old Jan 15, 2006 | 10:24 AM
  #111
Edward Lee's Avatar
Hmmm, Well it's a craftsman product. It's not on their site. $24.99! Call them nd see if they have one. Or just go to Home Depot, they'll have it 100% for sure.
Old Jan 15, 2006 | 11:07 AM
  #112
igzy's Avatar
I Know Kwaliti
Looking at the receipt from Home Depot I see p/n 131688... It is a compressor in-line water separator... Hope it helps...
Old Feb 3, 2006 | 07:06 PM
  #113
trigger005's Avatar
1/4 work?
Don't have a Home Depot near me... however, my local Walmart has everything... but in 1/4". Can that still work?
Old Feb 3, 2006 | 07:28 PM
  #114
Edward Lee's Avatar
I don't think that the inlet and outlet size will matter at all. As long as you get those hose fittings that are cone shaped you should be alright. Take pics when you are finished. If you want I can get one for you at sears.
Old Feb 3, 2006 | 09:49 PM
  #115
igzy's Avatar
I Know Kwaliti
1/4" fittings are fine, that's what I have
Old Feb 4, 2006 | 01:14 AM
  #116
i used 3/8...fits fine too
Old Feb 9, 2006 | 10:12 AM
  #117
teamsinister's Avatar
Great write up!! Did mod and is it bad that it is like a quarter full every few days? I drive like 60miles a day if that helps answer the question?
Old Feb 9, 2006 | 10:20 AM
  #118
95maxrider's Avatar
Lightly modded
What's the word on a canister that isn't made of plastic? When I went to HD they only had the normal one, and the plus size, both of which were plastic. Maybe something online?
Old Feb 9, 2006 | 10:25 AM
  #119
igzy's Avatar
I Know Kwaliti
Sinister - Great write up!! Did mod and is it bad that it is like a quarter full every few days? I drive like 60miles a day if that helps answer the question?
I drive 80 miles/dey and noticed the same on mine... I have been emptying it every couple weeks and most of the time it is almost full... I guess it is normal... On the bright side, note that would be the oil making it to your intake instead, i.e. gum-gum, ping-ping
Old Feb 9, 2006 | 08:08 PM
  #120
YuAnChen's Avatar
Will This work ?
http://cgi.ebay.ca/JDM-OIL-CATCH-RES...QQcmdZViewItem
