A33 Lower Tie Bar
Old Jul 18, 2005 | 09:55 PM
Talyan03's Avatar
A33 Lower Tie Bar
is it worth getting this product? A33 LOWER TIE BAR. is there anyone outhere who has this installed? please let us know. Thanks
http://www.liuspeedtuning.com/products/a33_tiebar2.html
Designed to tie the front suspension together to provide sharper steering response and better handling overall.
Ties together the bolts on the front lower control arm gussets.
Bolts onto an additional frame mount behind the control arms to provide more strength and reduce chassis flex even more than Stage I.
Powdercoated for protection, color can be specified in your purchase notes (extra charge may apply).
Old Jul 18, 2005 | 10:21 PM
Shogunsc4's Avatar
hmm... are these blemco stage 2 LTB?
Old Jul 18, 2005 | 10:24 PM
Talyan03's Avatar
not shore i think not
Old Jul 18, 2005 | 10:34 PM
Omegasrk's Avatar
I would say yes. Look here:
http://www.liuspeedtuning.com/a33.html
steve...
Old Jul 18, 2005 | 10:50 PM
Talyan03's Avatar
does it help???????????????
Old Jul 18, 2005 | 11:31 PM
NisMo-Max's Avatar
That looks like matt blemchos product, but not sure how much it helps...
Old Jul 18, 2005 | 11:36 PM
A33 VQ30DEK's Avatar
you should talk to irish44j. I believe he has this mod on his vehicle.
Old Jul 19, 2005 | 05:11 AM
doublea's Avatar
I can only talk about my own experience, I have D2 coilover on my max and the bar was scraping to much for my taste. It make a big difference in the handling though, if you have a FSTB and LTB STAGE 2 you will definitely feel the difference. On my max with the D2 and the LTB2, I had only 2" of ground clearance. The road are like 1920 trails overhere so it is one of the reason the LTB2 was scrapping regularly. If you dont have coilover than the LTB2 is a great add on, you wont regret it, I mean I love the bar but I had no other choice than remove it, but I'm going to try to modify it and see if I can regain 2" of ground clearance.
AA
Old Jul 19, 2005 | 07:06 AM
chr0nos's Avatar
Wow, they are marking it up. You can get it cheaper directly from matt. www.mattblehm.com. I got the stage1 bar along with Progress RSB a few weeks ago, and it makes a difference. I dont know what how much difference exactly since it put both front and back ltbs at the same time, but its a very nice change in handling if you dont have anything now. I wish i had gotten the stage 2 bar from matt, seems like it would stiffen up the front a lot better than just the stage1 ltb.
Old Jul 19, 2005 | 07:35 AM
Melaza's Avatar
It definetly helps alot...i had the blemhco stage two... could tell you it was a pita to install however it does make a significan improvement(in my opinion) however i took it off b/c i got s-tein and i was afraid on leaving the damm bar stock on a pothole...we got plenty of those here in nyc..
Old Jul 19, 2005 | 08:01 AM
doublea's Avatar
I hear you man, but I'm shure it's possible to modify the LTB2 to accomodate the additional drop from coilover or S-tein and other drop spring. Dont get me wrong the LTB2 is nicely design and well made. If your car is stock or near stock then there is no problem, the bar shouldn't scrape or very little maybe sometimes on a bigger pothholes. The LTB2 was on my car for about 2-3 weeks, with the D2, RSB, FSTB & ES bushing on, man this car was on rails.
Old Jul 19, 2005 | 10:36 AM
Omegasrk's Avatar
If you put Matt's website side-by-side, they are the same price minus shiping cost which may be variable. Therefore, same product, and maybe Matt has some sort of business ties with this company to sell his products.
steve...
Old Jul 19, 2005 | 10:51 AM
OOmaxSE's Avatar
is it true that the LTB stage II may be one of the most effective mod to reduce our wheel hops? that's word of mouth, so somebody clear this up, please.
Old Jul 19, 2005 | 11:35 AM
scopium
dude that thing works like crazy.. i have freind that has it on his car.. and that thing turns tight as a virgin.
a bit of clearance issue.. just have to becarefull on the speed bumps..
but other than that... its all good
Old Jul 19, 2005 | 11:45 AM
240se's Avatar
It looks exactly like the blemco stage 2 LTB. I put one on my 02 after putting on a RSB, FSTB, and Tokico Blues with the stock SE springs. Made a big improvement. I have had no problems with ground clearance at stock ride height.
Old Jul 19, 2005 | 11:47 AM
CCS2k1Max's Avatar
My first mod was the FSTB and to me that made a world of difference tightening the front end. When I put on the LTB, though it might have tightened the lower part of the front end, I personally did not feel that the improvement was as dramatic. Maybe if I had installed the LTB first and then the FSTB, things would be reversed; don't know.
Old Jul 19, 2005 | 12:19 PM
zax 20th ae's Avatar
I have a stage 2 tiebar from matt blehm still not on car yet but if yall really wanna know ask irish hes got one on his max...
Old Jul 19, 2005 | 02:57 PM
irish44j's Avatar
retired moderator
well worth it....go look up some of the long threads about this subject in the past.
looks like Matt has a distributor
user 11122324
42
Jul 18, 2022 03:35 PM
knight_yyz
Nov 1, 2015 01:34 PM
MaxLvr21
Oct 17, 2015 12:11 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
