Engine won't go past 2500 rpm
Old Jul 20, 2005 | 03:47 PM
Luds's Avatar
I tried to search a bit but couldn't come up with too much. Real quick, 02 max with a 6sp. Just driving home from work and traffic was stop and go so I moved over to the far right lane and step on it to get off on an earlier exit. Something weird happened and now the car has the equivalent of a rev limiter at 2500 rpms. The engine just cuts power if I hit that on the tech.
Any ideas?
Thanks in advance
Old Jul 20, 2005 | 03:49 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
you blew a mass air flow sensor I bet......
Old Jul 20, 2005 | 03:56 PM
upstatemax's Avatar
yeah its your mass air sensor...
Old Jul 20, 2005 | 03:57 PM
Luds's Avatar
I assume it's fine for me to still drive the car... like to the dealership to get this fixed.
How much does a Mass air sensor run? And how long would this take to fix?
Old Jul 20, 2005 | 04:07 PM
Tek-Niq's Avatar
I dunno how much it is, but its a quick replacement... take the old one out and install the new one... 5 minutes tops..
Old Jul 20, 2005 | 04:09 PM
upstatemax's Avatar
I know you can get one for my 00' for about $90, last I heard the 02+ were quite a bit more. like $200 range.
Luds's Avatar
Thanks for the help so far guys...
okay, so I went back out there to start it up and pull the car in the garage and I can't keep it running. It fires up and the tach bounces up and down slowly working it's way until it dies. Trying to "give it some gas" does not appear to help.
Any suggestions?
Old Jul 20, 2005 | 04:13 PM
Progress's Avatar
It's business time.
Your question has been answered. Your MAF needs replacing. If you are still unsure, you can run a diagnostic on it either at Autozone for free or the dealer for a labor charge.
GL
Old Jul 20, 2005 | 04:22 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
call Dave B for a new MAF...1-888-254-6060
Old Jul 20, 2005 | 04:34 PM
pruizgarcia's Avatar
Replace it with a 00-01 maf and you will save a ton of money. A new 5.5 gen maf is about $450. $120 if you can find one in a junk yard.
Luds's Avatar
Thanks...
I agree on the issue, it's just if I can't get the car started I really can't drive to get the part or take it to the dealership. I was asking for suggestions on getting it running even if to limp along to the dealership.
Old Jul 20, 2005 | 04:38 PM
Tek-Niq's Avatar
Originally Posted by Luds
Thanks...
the part is expensive as is.... get a ride over and install it yourself... i think is one screw and a clip and the whole MAF assembly comes off... real simple to do so don't waste money on labor on top of the MAF..
Old Jul 20, 2005 | 04:53 PM
Luds's Avatar
Thanks for the help...
God that part is expensive. I called around to 3 different stores and only Checker could get it. $280 and it would take 7 days. Gotta be kidding. Anyway, I'll figure something out.
-Thanks
Old Jul 20, 2005 | 05:09 PM
Luds's Avatar
One more question...
where exactly is the MAF?
Old Jul 20, 2005 | 05:10 PM
Tek-Niq's Avatar
right on the intake... right before the intake maniflod theres a sensor coming out of the shaft, can't miss it...
theres wires going to it, on the intake... you can't miss the assembly.... on the straight part of the intake not the box....
Old Jul 20, 2005 | 05:15 PM
Luds's Avatar
Sorry... not to be an idiot
but where is it relative to the air filter, that might help me. Is it it the thing that is kind of diamond shaped sticking out of the tube just past the air filter?
Old Jul 20, 2005 | 05:20 PM
Tek-Niq's Avatar
its closer to the engine... there's a straight pipe going to the engine after the filter box, its mounted there..
yes its sticking out of the tube...
Old Jul 20, 2005 | 05:22 PM
Luds's Avatar
Right before you get to the metal pipes? (intake manifold?)
Cuz I have it down to 2 parts.
Old Jul 20, 2005 | 05:26 PM
Tek-Niq's Avatar
I was going to post a pic, but my system is acting up....
but, yea in between the metal pipes (manifold) and the filter box.... on a straight pipe.
Old Jul 20, 2005 | 05:27 PM
Luds's Avatar
Thanks much for your help.
Old Jul 20, 2005 | 05:37 PM
Tek-Niq's Avatar
I dug up an old pic of my 02 max........
mvm062
Nov 30, 2020 09:00 AM
captchaos
Mar 15, 2016 12:18 PM
ballerchris510
Sep 10, 2015 09:35 PM
jfl330
Sep 4, 2015 01:44 PM
dcardello
Sep 3, 2015 11:44 PM
