Testing MAF
Old Jul 28, 2005 | 10:58 AM
2248's Avatar
Testing MAF
I'm having problems with my car stalling while coming to stops, and I'm thinking that it could be the MAF. Is there a way to test it before replacing it since I have no codes to tell me. Thanks for any input.
Old Jul 28, 2005 | 11:07 AM
AcerX's Avatar
You do know that if you have a manual and come to a stop and the clutch isn't engaged the engine shuts off.
Old Aug 1, 2005 | 02:57 PM
puett's Avatar
I'd try cleaning the throttle body first. Had similar stalling problem and cleaning the throttle body completely eliminated the problem. Easy to do it yourself. There's a helpful discussion somewhere on this forum with pictures and all.
Good luck!
Old Aug 14, 2005 | 05:47 PM
Eenis's Avatar
To echo 2248's question, is there a way to test the MAF? Also, is there a way to test the oxygen sensors as well? I got a P0170, did some research and someone posted that it could be the MAF. Either way, I'd like to drop my $100 only once to fix the problem. Any way to test the MAF?
Old Aug 14, 2005 | 06:20 PM
BewstAdd1ct's Avatar
fully warmed up under no load, no a/c, etc output should be 1.2-1.8V
though stalling when coming to a stop sounds more IAC-ish. id start there first.
Old Aug 14, 2005 | 07:43 PM
PoLo's Avatar
2-Wheelin it...
to test functionality of the MAF, here's a quick simple test. i've mentioned it a number of times but for some reason, it always gets ignored. blow into it. if the car shuts off, the MAF is good. if it statys on, that means the MAF's sensors aren't reading the values and sending them to the ECU. in other words, the car should react to your blowing into it.
i know, sounds too easy of a test, but it worked on my 91GXE and it ended up being an ECU issue. the MAF was perfectly fine. again, if it shuts off, that's a good thing. A/F ratio's are uneven, thus causing the car to cough, and if enough air is blown in, it shuts off.
hope this works out.
Old Aug 14, 2005 | 07:50 PM
good suggestion, but that only works on a MAF that isnt reading at all, which usually throws a CEL.
a contaminated MAF will just give a skewed reading, and blowing into it can and will throw you into a completely rich map causing a stall.
basically, if your car stalls from blowing into the maf, it doesnt mean the maf is good.
Old Aug 14, 2005 | 08:11 PM
Eenis's Avatar
Bewst, I'm guessing this gets tested with a multimeter, correct? or is there a way to test this w/ an obdII reader? if using a multimeter, where do you attach the points in order to take this reading? much appreciated.
Old Aug 14, 2005 | 08:23 PM
either/or
a scanner would be better because you can get a g/s reading, but a DMM should work, for idle anyway. ck voltage at r/g pin4 at the MAF, should be B+. i think the red wire (which is the AVCC wire) is the VREF and white is the signal, AFAICT... only one will be in that range at idle
Old Aug 15, 2005 | 06:29 AM
Eenis's Avatar
either/or
Can you break down the abbreviations? g/s, avcc and vref? Thanks.
Old Aug 15, 2005 | 03:09 PM
B+ is battery voltage, VREF is reference voltage, im not sure if thats what AVCC stands for, but id expect 5V from it. g/s is grams per second. only one wire should have that signal voltage on it at idle, id ck the white one on pin1.
Old Aug 15, 2005 | 03:48 PM
ftlmax's Avatar
Maf
Wasup every body i have a 2002se 6spd max, the other day while racing a lancer evo my car started acting up when i pressed on the gas so i pulled over to the side after my check engine light came on, engine sounded fine, the car drives alright but if i go over 2500 rpms in any gear car starts to sputter, as long as i stay under that i can still drive around, took it to get the check engine light checked and these codes came up-p0102 maf sensor low input-p1102 manufacture controll fuel/air- and IAT sensor high input, my question is if the mass air flow sensor is bad could it be causing these other codes to pop up because of that?
Old Aug 15, 2005 | 04:38 PM
those codes actually sound like an unplugged sensor, or open ckt... check the connector and ck voltage at it.
Old Aug 16, 2005 | 02:16 PM
ftlmax's Avatar
ftlmax
hey maxamaniac thanks for your responce i was just curious what do you mean by ckt?
Old Aug 16, 2005 | 02:22 PM
ftlmax's Avatar
Also If Anyone Knows Where I Can Get A Mass Airflow Sensor For My Car Give Me A Holler, Or If You Can Explain To Me How To Convert A 2001 Max Mass Air Flow Sensor To Work On My Car, AGAIN IT'S A 2002 MAX
Asap
Old Aug 16, 2005 | 04:36 PM
ckt = circuit.
get a MAF from DaveB, hes the best unless you get wholesale prices, form what i hear. converting AFAICT is as easy as buying an external IAT and its required wiring.
Old Aug 17, 2005 | 11:53 AM
ftlmax's Avatar
Hey maximaniac do you know how i can get ahold of daveB, and also do I have to reset my ecu when I install the new maf even if it's the stock one?
Old Aug 17, 2005 | 04:21 PM
hey newbie just registered, its a good idea to reset the ECU and run the throttle learn and idle volume learn, etc...
i dont have daveB's number off hand, but several others do.
Old Aug 21, 2005 | 01:39 PM
ZIPPIN's Avatar
Mauja He Mauja
i changed the maf again today. 3rd one. no SES light, but she was not as responsive. awwww yeah babe. power is back. i think our MAF's need changed every 30K...
TallTom
57
Oct 14, 2025 05:16 PM
tarun900
19
Dec 20, 2021 06:57 PM
knight_yyz
Nov 1, 2015 01:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
