Tips on installing Stillen Classic kit
Old Aug 1, 2005 | 06:09 PM
MacAlert's Avatar
Ok, I know this has probably been discussed before. I'm going to be doing the install myself in my driveway, no special tools, nothing. I might have to buy a rivet gun. Now, I need to know EXACTLY where i SHOULD rivet the kit in place. Its going to be front, rear and sides. Thanks in advance.
Old Aug 1, 2005 | 06:27 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
use screws, that way you can remove the kit w/o any problems... my .02... get the 3M red double side tape... and good luck....
Old Aug 1, 2005 | 07:02 PM
MacAlert's Avatar
Any special types of screws? I'm going to rivet the sideskirts in. I really don't plan on removing the kit, unless I decide to repair my front bumper.
Old Aug 1, 2005 | 07:48 PM
Lontar1's Avatar
I use regular screws on the front xorners and the rear... no special screws.. really easy to do......
Old Aug 1, 2005 | 09:51 PM
Talyan03's Avatar
Make shore the surface will be cleaned with rubbing alcohol. Because when u applie the double sided tape it will not hold well if the pain has wax or dirt on it. And lay cardboards and towels to prevent lip and side skirts from scratching in case if they will fall during installation. It’s better to have a buddy who can help you. You will need some one to hold the parts wile you are drilling the wholes.
Old Aug 2, 2005 | 03:11 AM
MacAlert's Avatar
Again, where am I drilling holes?
Old Aug 2, 2005 | 02:43 PM
NISMAX03's Avatar
I only drilled holes inside the wheel wells. I used three screws on each side with the front and rear lip. The rest I used the 3M double sided tape. I kept the OEM side skirts on.
MaxLife17
Sep 8, 2015 02:36 PM
Johnny9595
Sep 3, 2015 05:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
Justin Kroll
Sep 2, 2015 11:06 AM
A32goldylocks
Sep 2, 2015 06:39 AM
