Quick question
Old Aug 4, 2005 | 08:35 AM
boondoxmax's Avatar
Quick question
I am having some tokico hp put on my 2003 max and the guy told me that an alignment isn't needed. Is this true. Also is there a way to tell if the previous owner of a car had lowering springs on before they traded in the car. Everything is stock but my struts are very soft front and rear. It seems to early for my car to need struts....40,000 miles.
Old Aug 4, 2005 | 11:53 AM
BewstAdd1ct's Avatar
ive NEVER worked on a car that didnt need an alignment after struts.
my 91 needed it... its just a toe adjustment. front camber/caster isnt adjustable.
Old Aug 4, 2005 | 11:57 AM
AcerX's Avatar
Everything is stock but my struts are very soft front and rear. It seems to early for my car to need struts....40,000 miles.[/QUOTE]
It shouldn't be soft...unless the previous owner went off roading with it.
Old Aug 4, 2005 | 12:03 PM
boondoxmax's Avatar
It shouldn't be soft...unless the previous owner went off roading with it.[/QUOTE]
I think he had performance springs on the stock struts. I looked in the trunk to see if the lining looked like it had been removed and it does. So i figure he probably put the stock springs back on it when he traded it in.. . But i even called the dealer for a quote and the also said no alignment needed...WTF
Old Aug 4, 2005 | 12:06 PM
struts dont always fail just from normal wear. sometimes theyll leak which of course, would cause premature failure.
Old Aug 4, 2005 | 12:17 PM
AcerX's Avatar
All of the the struts are leaking?!
Old Aug 4, 2005 | 12:26 PM
i dont know, bring the car to me and ill take a look at it for you. i cant accurately diagnose it over the intarweb
Old Aug 4, 2005 | 12:29 PM
2K3MAX2NV's Avatar
"tse-tse fly"
I had HP's installed in april without an alignment and have no problems at all I just had the car aligned a few weeks earlier
Old Aug 4, 2005 | 02:40 PM
boondoxmax's Avatar
I checked for leaking. no leaking and i was told that bad shocks don't always leak. I had an 02 auto before this 03 6sp and the car road alot stiffer..My ride is kinda choppy and i don't think it should be a difference in ride quality from auto to stick..
Old Aug 4, 2005 | 06:37 PM
no, it shouldnt... and yes, its true, bad shocks dont always leak, but a leaking shock is always bad
have you given it the 'bounce test'?
Old Aug 5, 2005 | 06:03 AM
boondoxmax's Avatar
yes i pushed down on the corners and it bounces twice sometimes and then if i do it i won't bounce twice like the shock is prefect...
Old Aug 5, 2005 | 10:14 AM
hmm... that is wierd.
Mar 12, 2020 12:06 AM
pears
Sep 18, 2015 05:25 AM
ef9
Buyer/Seller Feedback
Sep 10, 2015 10:13 PM
Johnny9595
Sep 3, 2015 05:18 AM
