How to install spark plugs?
Old Aug 7, 2005 | 05:34 PM
xUltra's Avatar
Do we have a 2000-2001 spark plug replacement howto? The ones on the instructions post do NOT work... anyone have any others, I saw the 5.5th gen howto, so it should be similar..
Old Aug 7, 2005 | 05:40 PM
SoonerFan's Avatar
Cletus
im pretty sure its in your owners manual
and if you are going to reply with "i dont have one", today is your lucky day
download one http://www.nissan-techinfo.com/nissa...p?dept%5Fid=37
Old Aug 7, 2005 | 05:58 PM
jjames's Avatar
remove old spark plugs.
put in new spark plugs.
Old Aug 7, 2005 | 06:24 PM
xUltra's Avatar
You know, and I actually don't have one, my Maxima friend borrowed it and never gave it back :O!
thanks jjames, your help was greatly appreciated!
Old Aug 7, 2005 | 07:47 PM
jjames's Avatar
ok,ok.
remove the engine cover from the front of the engine. you'll need an allen wrench.
under the cover you'll see the 3 ignition coils. there is a green clip on them.
press down on the green clip until you can remove the harness from the ignition coil. this isn't absolutely necessary, but it'll make it easier.
remove the bolt holding the igntion coil in place. you'll need a 10mm socket.
repeat for the others.
now you can remove the spark plugs and put in the new ones.
now you need to do the ones in the back. you will need a long extension on your ratchet to get to the rear spark plugs. these are far more difficult to change than the fronts. i find it helpful to loosen the throttle cable and set it off to the side. make sure you have one of those claw grab it type tools handy. you'll probably need it. after you loosen the 10mm bolts from the rear ingnition coil, it's easiest to CAREFULLY remove the socket, and reach in with the grab it tool to get them. that is unless you have a magnetic socket. i use the grab it tool to get them started again when i re-install the ignition coils.
be sure to put some anti sieze on the threads of the new plugs.
be sure to gap them too.
better?
edit: and btw, if you're asking how to replace spark plugs, please don't do this job yourself. this might sound harsh, but if you need a write-up on how to change spark plugs, you could easily screw something up. be careful. you don't want to go dropping bolts into your engine.
Old Aug 18, 2005 | 01:44 PM
xUltra's Avatar
yeah well changing plugs on a maxima is a ***** :\
Old Aug 18, 2005 | 02:51 PM
DrKlop's Avatar
Driving is the next best thing
I am changing my plugs in like two hours. Are you sure that 2000 model plugs need to be gapped?
Old Aug 18, 2005 | 03:35 PM
Whtmax'01's Avatar
manual states not to gap them , by the way when u installing the new plugs u can use a piece of rubber tubing to get them started so that u dont strip the thread.
Old Aug 18, 2005 | 03:58 PM
DrKlop's Avatar
anyone knows the correct gap size for vq30de-k (just to make sure that they do not have to be adjusted)
Old Aug 18, 2005 | 05:11 PM
BewstAdd1ct's Avatar
theyre platinum tipped, you dont gap them because supposedly the platinum tip gets worn away...
theyre pre-gapped. put them in.
Old Aug 19, 2005 | 06:33 AM
igzy's Avatar
I Know Kwaliti
no gapping on most plugs nowadays...
Old Aug 19, 2005 | 09:44 AM
jjames's Avatar
sorry. i didn't see where he said he was using platinum plugs.
btw, i don't care if they are gapped at the factory. i'll take the extra 5 seconds to make sure some monkey at the factory gapped them properly.
Old Aug 20, 2005 | 07:47 AM
Machine*
yeah, just dont scratch the platinum tip.
Old Aug 20, 2005 | 07:50 AM
ZIPPIN's Avatar
Mauja He Mauja
pm me your email addy and i will send you the how-2
Old Aug 20, 2005 | 01:56 PM
Ammi's Avatar
350 Detroit Muscle
wow dude, that was really helpful.
I'll send you a link on how to when I get home
Old Aug 25, 2005 | 02:03 PM
kam1luv's Avatar
Remove wires and then the plugs and replace with new ones.
Old Aug 25, 2005 | 04:59 PM
MCE's Avatar
MCE
Use a piece of vacuum or any rubber hose that is a suitable inside diameter to slip over the plug to remove and install them easily.
MCE
Old Aug 25, 2005 | 06:50 PM
jjames's Avatar
if you (kam1luv) are holding a wrench, get away from your maxima.
Old Aug 26, 2005 | 10:54 PM
callmezeus's Avatar
There is a first time for everything. I once paid a guy $15 to install a disk drive on my computer 7 years ago.....man I was such a noob.
Old Aug 27, 2005 | 03:57 PM
youre one to talk, mister "remove old spark plugs, put in new plugs"
Old Aug 27, 2005 | 06:50 PM
jjames's Avatar
hey, at least i didn't tell him to replace the spark plug wires on a 5th gen. maxima.
mvm062
Nov 30, 2020 09:00 AM
9aj9
Apr 5, 2020 12:11 AM
MaxLife17
Jun 27, 2019 01:37 PM
Johnny9595
Sep 3, 2015 05:18 AM
