P1320-Ignition Signal, what would be the cause
Old Aug 9, 2005 | 05:54 PM
reMaxxxK's Avatar
Ok guys, start my car this morning first time of the day, the idle was little rough around 750-1000rpm, and then the light came on and the idle smooth again.
Run another 200 miles on highway and bring it to my favourite mechanic after work, pulled the code out read the P1320, oh forgot to mention, the car was run smooth as new after the light is on, doesn't have any problem restart the car. (I had made few stop at work) the idle was just back to normal like nothing happen before.
I had reset the ecu, the light never come on again till now(I had made few stop after the check up), the question is it there a early sign of something might be break soon?
The car right now at 79k miles, bought it used don't know about the spark plug has been change or not.
Old Aug 9, 2005 | 06:19 PM
Inspiron's Avatar
check if you have the new ignition coils installed.
the new ones have a grey dot.
Old Aug 9, 2005 | 07:53 PM
reMaxxxK's Avatar
apparently not.
Old Aug 9, 2005 | 08:07 PM
jjames's Avatar
ok, 1st of all, my ignition coils have the grey dot, and they have never been replaced. i checked.
2nd, did you pull another code? if you did, you should have pulled a P050X. the x denotes which cylinder is misfiring. if it's p0500, it's a multiple misfire.
anyway, it's most likely a coil. so here's what you do. warm up you car until it starts to show the same symptoms. then disconnect the coils 1 by 1. when you get to one that doesn;t make the engine bog, you've found the bad coil.
Old Aug 12, 2005 | 12:23 PM
dvanorder's Avatar
This 1320 is really pissing me off. Mine just came back from the shop after 2 days of NOT finding the problem. I've swapped coils and plugs. Car seems to run fine--I was getting intermittent P0134's a few months ago but they stopped and were replaced with P1320. I usually do not notice when the SES goes on, only once did it stumble before tripping SES, at low idle pulling out of a parking lot.
I've got an 100K EW with 11.5K left so no worries, but it's irritating to say the least. I am having serious doubts I will get the desired 175-200K miles out of this thing despite maintenance and TLC. Maybe she's just pissed cause there's a C5 Vette sitting in the garage ;-)
Old Aug 12, 2005 | 06:51 PM
BewstAdd1ct's Avatar
you the original owner? and you checked all of your warranty invoices?
thats p03xx
but other than that, youre right on.
dvanorder, if youve got the CEL on and the fault present, the dealer has NO REASON not to find the fault, and fix the problem. its likely a coil, any experienced dealer tech will start there first, runa power balance and find the faulty cylinder, and swap coils to confirm any suspicion.
same goes for the thread starter. when you can catch it running rough, do what jjames said and unplug one coil at a time. the culprit will be the one that doesnt make the engine bog any further.
Old Aug 12, 2005 | 07:07 PM
96sleepergle's Avatar
check the ignition system not just the coils the system which the ecu uses to determine igniton timing is the air intake temp sensor, coolant temp sensor crankshaft position sensor (pos) crankshaft position sensor (ref) and camshaft positon sensor, i had the same code changed the coils reset the ecu and the code came back so i looked at the nissan service manual and all those sensors i mentioned is what the ecu use to determine the ignition timing thats why the ecu is tell (p1320 primary igniton at fault) meaning some where in the primary system theres a problem it turned out to be the air intake temp sensor thats part of the ignition circut most people dont even know that, also hanyes has a list of all the maxima sensor and what they are used for
Old Aug 12, 2005 | 07:56 PM
primary ignition is the low volage side of the coils. the control side. the 12V constant and a switched ground, wheras the secondary ignition is the secondary half of the coil, the electrodes and spark plugs. and in a conventional ign system, the spark plug wires, and cap and rotor if applicable.
Old Aug 12, 2005 | 08:17 PM
reMaxxxK's Avatar
Humm, let me think, I had put on K&N filter with stock filter box and replace pcv valve, about few days before the light came on, is there any related to this code? Anyway I am going to replace the spark plug and see what's going on, running 80k miles on use car didn't know it had been replace or not.
Old Aug 12, 2005 | 08:25 PM
try the power balance first.
Old Aug 13, 2005 | 09:27 AM
callmezeus's Avatar
I think I got Jinxed by reading this post. j/k I come back from my vacation and my car throws the ignition coild code. . I sent dave B a email, hopefully he can help me out so I dont have to manwhore for money to buy new coils somewhere else.
Old Aug 13, 2005 | 02:40 PM
Weimar Ben's Avatar
Helicopters! Money!!!
There's a TSB for this. It says that the problem is either ignition coils, or the engine wiring harness. This code usually comes about as a result of 1 or more bad coils.
Don't take it to a dealer, they will rip you a couple of new ones. My dealer wanted $700 for the coils and another $1500 to replace the engine harness. I ordered new coils for $260 and installed them in 15min. Problem fixed and it runs like a champ.
Old Aug 13, 2005 | 06:23 PM
callmezeus's Avatar
Just wondering, where did you buy your coils from. I'm trying to shop around.
Old Aug 13, 2005 | 06:39 PM
jjames's Avatar
second owner. but i called the dealer and they said they were never replaced. i suppose it's possible that the 1st owner bought the coils herself and installed them herself, but i doubt it. i'll check with her though.
thats p03xx
christ. i'm a retard.
Old Aug 13, 2005 | 08:01 PM
Weimar Ben's Avatar
I don't remember. The easiest, and maybe cheapest would be to call Dave B. Look in the stickies for his number.
Old Aug 14, 2005 | 09:11 AM
reMaxxxK's Avatar
The light went off automaticaly, it's that means something? nothing had been done yet. any clue?
Old Aug 14, 2005 | 09:12 AM
nismo_star's Avatar
check grounds by oil filler cap towards passenger side and towards firewall are two engine harness grounds.
check to make sure no excessive rust or corrossion or loose.
clean and/or tighten as necessary.
Possible harness breakage where harness goes over rear of motor on passenger side by firewall, shake it when car is running, if engine starts to hesitate or surge, you may have a harness condition.
Old Aug 14, 2005 | 10:00 AM
^^good call... and dont forget the wiggle test...
Old Aug 14, 2005 | 01:01 PM
Weimar Ben's Avatar
If you drive long enough without misfires, the light will go off.
Old Aug 14, 2005 | 01:17 PM
AFAIK, the 1320 isnt a misfire code, its an electrical failure code.
Old Aug 14, 2005 | 02:44 PM
Weimar Ben's Avatar
True, but that's not how it's to be interpreted. Go read the TSB. This code is thrown due to bad coil(s) or a bad engine wiring harness.
Old Aug 14, 2005 | 02:57 PM
ive read the TSB, but driving without misfires doesnt mean the light will turn off. i know why the code gets thrown
Old Aug 17, 2005 | 03:23 PM
MAX HARDCORE's Avatar
I replaced my coils about 2 months ago after 1320's all over the yard. Runs like a dream. Mine had a red dot on them though????
Old Aug 17, 2005 | 05:28 PM
those with p1320, refer to this thread as well
http://forums.maxima.org/showthread.php?t=423141
Old Aug 20, 2005 | 11:23 PM
callmezeus's Avatar
Dave B is the man. I ordered coils from him and he sent them out the next day. The car finally runs like it should.
Old Aug 21, 2005 | 08:22 AM
plz mark the failed coils and send me your old ones. or just the failed ones
Old Aug 21, 2005 | 05:43 PM
dvanorder's Avatar
I may be sending you one of mine from the front bank #6; it failed after a few hundred miles---it's a 'new' 22448-2Y005. I wonder though, not all of them were sealed, the gray box tape was broken on a few of them. I am hoping the vendor will replace it since it did not even last 2 weeks. If I gotta eat it, a) I'll be real pissed and b) it's yours.
Old Aug 21, 2005 | 05:51 PM
Weimar Ben's Avatar
How much were they?
Old Aug 21, 2005 | 06:46 PM
callmezeus's Avatar
$58 a piece. . Not Daves fault the price went up on them. Even still The stealership near my place wanted $98 each. And my friend who works for a Firestone would of only been able to get them for $68. Take those numbers and multiply them by six and I got some big savings from Dave. I replaced all of them to go ahead and get it out of the way. I need to check which one is faulty.
Old Jan 21, 2007 | 08:13 PM
WhaMaxDoYaHave's Avatar
I replaced my coils and I still get the 1320 code. No more problems with the idle though. I reset the comp but it still comes right back with the 1320 code. Whats the deal???
Old Jan 21, 2007 | 10:30 PM
crazixpaki's Avatar
I still have the same issue, i have heared that one has to reprogram the
ecu through the dealer, how true is that? The dealers in my area are not
very helpful.
Old Jan 23, 2007 | 07:38 PM
max2di4's Avatar
I have the famous P1320 code and I changed all the coils. I notice on back coil on the passenger side when I unplug no change in the engine. I changed the coil pack with the one next to it and still nothing and I check the harness to the coil. Any ideas.
Old Jan 23, 2007 | 10:40 PM
Weimar Ben's Avatar
It can only be two things, the harness or the coil. Period. There's a TSB about the harness going bad at an ugly 90deg bend on the right side.
Old Feb 6, 2007 | 12:12 PM
Mikeb120's Avatar
How do you replace the coils?
Old Feb 6, 2007 | 01:50 PM
bigfatty's Avatar
Booyah grandma.... BOOYAH
See my sig
Old Mar 20, 2007 | 06:12 PM
lalaMAX's Avatar
i am having the same problem with reMaxxxK engine light came on couple times for the last month, and it went off it self, anyway it went on today went to Canadian tire for OBDII scaning, only P1320 came on...
symptom was car shakes a little when i crank start my car, SES, SLIP, ABS was on, but it only last no more then a minute.... the car runs perfect... so is that means 99% coil?
Old Mar 20, 2007 | 06:57 PM
lalaMAX's Avatar
yah by the way what's the part number for updated coil? i couldnt find any><
Old Mar 21, 2007 | 08:44 AM
Mints33's Avatar
The TSB calls for the ECCS wiring harness to be checked for damage or broken. Are these wires that fragile? We are talking about the whole harness which runs to the computer and all, correct? I assume a dealer will have to do this?
Old Mar 21, 2007 | 08:45 AM
Mints33's Avatar
The part # is the same, however the updated ones will have a grey dot on them.
msellas
Sep 23, 2015 09:16 PM
chernandez1278
Sep 16, 2015 01:18 PM
BrandonCause
Sep 14, 2015 10:41 PM
