What will happen if...?
Old Aug 9, 2005 | 09:25 PM
wheeldream76's Avatar
What will happen IF i replace/swap the Engine computer of my 2003 Maxima with an Engine computer from 2002 Maxima with less miles>? Would my car take it and work with it fine? Would it create any problems/engine check lights, etc? Where is the mileage information stored?
The reason i am asking is because i have a spare engine computer from 2002 Maxima and i would like to chip it and keep my stock one intact. However, when i swap them, i don't want to fry/break something.
I've done this before on Audi S4 and A4 with 2.8, but i need to know how the Maxima will take it. Anyone done it?
Thanks!
Old Aug 10, 2005 | 11:13 AM
BLUEMAX01SE's Avatar
oh its easy! yeah when you put the one with less miles in, your engine will think the car has less miles thus the engine will perform much like a newer vehicle! go ahead try it! hope you have warranty! just in case it doesnt work out!
Old Aug 10, 2005 | 11:19 AM
NmexMAX's Avatar
dot dot dot ...
It will be fine ...
Old Aug 10, 2005 | 11:37 AM
chr0nos's Avatar
what???? how would an engine perform like a newer vehicle???
as engine wears out, the sensors send different info into the computer, and it adjusts timing/air/fuel ratios, etc, etc. over time.
the new ecu would start reading all the sensor info, and adjust itself to fit the enine's needs. so if it's an engine with high milage, the car will drive like a car with high milage, new ecu or not.
by the same token, a car with 200k miles with an ecu with 20k miles would magically transform into a brand new behaving vehicle????
Old Aug 10, 2005 | 11:38 AM
NmexMAX's Avatar
dot dot dot ...
I hope it was sarcasm
Old Aug 10, 2005 | 11:48 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
Thanks!
if you are considering anything besides the technosquare ecu then save your money. the "chips" for the audis typically work because many are turbo and the new settings typically raises boost levels. the technosquare l spec could raise your rev limiter and dump the top speed limiter.
Old Aug 10, 2005 | 12:06 PM
Ammi's Avatar
350 Detroit Muscle
where did you get your info from???
Old Aug 10, 2005 | 01:30 PM
UGAd13's Avatar
Hello Everyone,
I'm sarcasm. Have we met?
Old Aug 10, 2005 | 01:49 PM
NmexMAX's Avatar
dot dot dot ...
Apprently not all memebrs have met Mr Sarc. Eitherr that or sarcasm > them
Old Aug 10, 2005 | 04:02 PM
Derrick2k2SE's Avatar
I think the computer would have to be reflashed to work. Technosquare says they will take your computer and another computer and reflash the new one to work with your car. That way you could return to stock or tune with one for different conditions... whatever. If the computers were plug and play they wouldn't be offering that service and charging $150.00 for it.
A call to Technosquare could answer the question.
aw11power
Oct 10, 2021 04:57 AM
mkaresh
Mar 12, 2018 06:48 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
