Finally Fixed High Idle
Old Aug 12, 2005 | 08:24 PM
traderfjp's Avatar
A quich update: I cleaned my TB while the car was running (02 Max) and afterward had a CEL and high idle. I lived with it for a few months and then I pulled the code via Autozone. The code called for an IACV. The delaer wanted 700.00 and aftermarket was 300.00. I found a used one on the net for 125.00. I installed it tonight. I then did the idle procedure using the peddle. I've started the car about 10 times and the idle is back to normal. Finally!!
Old Aug 12, 2005 | 08:27 PM
BewstAdd1ct's Avatar
question... did you try doing the idle lean procedure BEFORE you replaced the iac?
Old Aug 12, 2005 | 08:46 PM
traderfjp's Avatar
Many, Many times.
Old Aug 13, 2005 | 09:02 AM
lol, good deal.
glad you got everything back to spec
9aj9
Apr 5, 2020 12:11 AM
bryants95max
Oct 2, 2015 12:52 PM
97_GXE
20
Sep 17, 2015 08:12 PM
seesole
Sep 14, 2015 12:38 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
