AC Controls doesn't iluminate any more
The lights on the AC controls in my 2000 i30t doesn't iluminate any more, how can I do to change the bulbs on that area ? I have checked all the fuses and everything is OK, even the AC controls work as usual, but they don't iluminate theirself anymore, what could it be ? Thanks in advance for your help !
if everything else is working on the dimmer switch, like the radio, ashtray, etc, pull out the control head and check power, you should have B+ at a red/white wire at pin 24, and variable ground at pin 25, which is a red/yellow wire. if that checks okay, its an HVAC unit internal failure, you can replace it or attempt to repair it. let us know what you find and well go from there.
