i30t rear deck...
Old May 24, 2001 | 11:26 AM
TimW's Avatar
The silent but deadly Moderator
anyone know if the rear deck would accept the i30 deck with rear sunshade... that'd be nifty...
Old May 24, 2001 | 01:59 PM
azylstra's Avatar
Can't tell you for sure but I can tell you this:
My dad has a 2000 I30 with the moonroof/sunshade delete option. Yes, that's right, a reverse option. The rear deck appears to be the same as a Maxima. It's easy to spot because it uses the same center high mount stop light (CHMSL) as the Maxima - narrow, one bulb design vs. wide, 5 bulb design. He wanted it without the moonroof/sunshade because he never used the moonroof in the old 86 Maxima and it eventually developed rattles, wind noise, and rust spots. Couldn't see the need for a sunshade because we always get the windows tinted.
Old May 24, 2001 | 09:18 PM
TimW's Avatar
I might...
call the junk yards and if I can find a rear deck with a motorized sunshade... I bet $$$$
Old May 24, 2001 | 11:09 PM
azylstra's Avatar
Just make sure to get the right color...
Another issue: The switch for the sunshade is in the center console. And since Max/I30 have different consoles, and the Max is not available with a sunshade, maybe there's no place for the switch. And maybe the car isn't wired for the switch or the shade. Lots of technical considerations. You would need to talk to a knowledgeable Nissan/Infiniti parts guy.
Also, I'm curious why you want a sunshade so bad. Doesn't window tint do the same thing?
Old May 24, 2001 | 11:31 PM
TimW's Avatar
I dont really want tint...
and as it gets hotter, that would be kinda cool.. no pun intended
Old May 25, 2001 | 04:49 AM
TexMaximum's Avatar
It is cool, and works even if you have the windows tinted anything less then limo style. It gets conversation all the time, plus you can attach a "Smoked Yea" Sign to it, and hit the button when you pull ahead
Anyhow, it would cost alot as it became standard on the I30 for only about a year, so not much of a demand for that part and is likey not worth it unless you find one low cost and will install it yourself.
What I want to do is get the new Q's side mirrors, with the LED turn signals
Old May 25, 2001 | 06:11 AM
DAVEB's Avatar
The part #'s for the I30 parcel shelf w/o the shade are the same as a Maxima. Infiniti list on the shade assembly is $929.35, the parcel shelf ranges from $137.23 to $296.73, depending on color. Better check the boneyards!
Old May 25, 2001 | 06:47 AM
TimW's Avatar
that is quite a commitment to a rear shade.
that *is* expensive. I'll make a few calls, although my experience is that the junkyards are 95% retail :/
big thanks for looking up the prices and the info.
matts95max
Apr 23, 2025 10:44 AM
GregL65
Jan 17, 2020 08:01 PM
The Wizard
24
Oct 1, 2015 08:47 PM
bbsitum
Sep 11, 2015 04:55 PM
