foul sulfur smell gets inside cabin.
Old Aug 17, 2005 | 11:05 AM
Whtmax'01's Avatar
I am pretty sure it is the cat that is malfunctioning, i dont know which one it is though. I changed the rear cat a while ago, so are there 2 cats left in the front? How much is each cat? I had a ses light Po420 which is due to bad cat, since i changed 02 sensors and that didnt do anything. car has 95k miles.
Old Aug 17, 2005 | 11:24 AM
BikTrash's Avatar
sounds like you scraped a hole in one of the cats
Old Aug 17, 2005 | 04:15 PM
BewstAdd1ct's Avatar
hed definately hear that... you probably have a failed cat or an exhaust leak... im guessing the consensus will be buying headers and/or aftermarket cats.
Old Aug 17, 2005 | 04:16 PM
Mass_Media's Avatar
Mass_Media™
headers, and y-pipe just to be safe....
Old Aug 17, 2005 | 05:34 PM
which would probably be cheaper than a set of cats and install from the dealer
Old Aug 17, 2005 | 05:40 PM
SoonerFan's Avatar
Cletus
seems you guys dont know all that much about exhaust.
2 pre-cats in the stock y-pipe (aftermarket would fix that)
BewstAdd1ct, why do you need headers?? especially for a 01?
and that still leaves you with the main problem..the main cat. thats between the y-pipe and b-pipe.
mass media, headers AND y-pipe arent gonna fix that
to remove all cats and fix the problem on an 01 - aftermarket y-pipe + high flow cat or straight pipe
Old Aug 17, 2005 | 05:53 PM
nobody needs headers. in fact, i didnt even suggest headers. i just guessed that it would be the general consensus since i really know nothing about aftermarket products for maxima exhaust.
hey... didnt someone already suggest that?
and i also said 'and/or aftermarket cats'
meaning, the consensus might not come to header replacement. thats all.
good try, though
Old Aug 17, 2005 | 06:53 PM
Whtmax'01's Avatar
last time my car was inspected , the guy raised the car and looked for a while at the front exhaust, so will they know that the cats been removed if i put ypipe ? Anyone in massachusetts with y-pipe go through inspection?
Old Aug 17, 2005 | 07:38 PM
Mass_Media's Avatar
Mass_Media™
Never said they would.....I just said Headers and y-pipe to be safe just incase it is those....and if it isn't....then you'll have headers and a y-pipe.....
Old Aug 18, 2005 | 12:31 PM
SoonerFan's Avatar
Cletus
headers dont do anything on a 3.0
Old Aug 18, 2005 | 04:24 PM
i hear they route the exhaust gasses into the y-pipe and 'what have you' for safe exit at the rear of the vehicle
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
AaronL
Aug 8, 2020 10:31 AM
homewrecker
Sep 24, 2015 07:01 PM
carid
Sep 17, 2015 05:00 AM
