How to reset airbag light? Help please
Old Aug 17, 2005 | 07:59 PM
reMaxxxK's Avatar
had try search on how to, the link doesn't work, anyone know the trick?
Old Aug 17, 2005 | 08:19 PM
Spin20's Avatar
Mine went off cause i unplugged a connection for it and the only way I found to reset it was to take it to the dealer and have them do it.
Old Aug 17, 2005 | 08:20 PM
ecsdesignz's Avatar
Codename: Frankie
Mine came on when i put I35 seats in my max. (still on) Last time i took it to the dealer for the airbag light they charged me 400 bucks for a sensor. Never again
Old Aug 17, 2005 | 08:21 PM
reMaxxxK's Avatar
yeah this is happen to my frien too, not me. he took off the seat and unplug it, never get if off again. there is some trick post on how-to but link broke down, maybe delete or long gone.
Old Aug 17, 2005 | 08:22 PM
Spin20's Avatar
I slipped a tech 10 bucks and he did it in about 30 seconds with a consult tool
reMaxxxK's Avatar
wooooooooo..........400 is killing
&^^$@# stealership, charge me 20 for trans pan gasket, bought one from Advance auto part $3
Old Aug 17, 2005 | 08:24 PM
reMaxxxK's Avatar
so the odbII scanner can reset the light? I know it can reset the ecu.
Old Aug 17, 2005 | 08:27 PM
Patsmax's Avatar
Here you go I had it saved on my pc
2000-2003 Airbag Light Reset Procedure
If your airbag light is on (or flashing)... try this. By the way, use a stopwatch to count.... the timing must be accurate in order for it to work.
1) Turn IGNITION on (but don't start car)
2) After the AIR BAG warning lamp lights for 7 seconds, turn IGNITION off within 1 second.
3) Wait 4 seconds
4) Turn IGNITION on (but don't start car)
5) After the AIR BAG warning lamp lights for 7 seconds, turn IGNITION off within 1 second.
6) Wait 4 seconds
7) Turn IGNITION on (but don't start car)
8) After the AIR BAG warning lamp lights for 7 seconds, turn IGNITION off within 1 second.
9) Wait 4 seconds
10) Turn IGNITION on (but don't start car)
11) Wait 3 seconds
12) Turn IGNITION off
13) Wait 2 seconds
14) START Car (the light may be blinking slower than before)
15) Wait 3 seconds
16) Turn IGNITION off
17) Wait 3 seconds
18) START Car
The light should be gone unless the problem remains. Try it again if it fails. If it still remains on, you'll need to visit a dealer to have the problem looked at.
Old Aug 17, 2005 | 08:28 PM
prince_starbai's Avatar
open your car door. turn the key to the on position. push the door pin switch at least 7 times in 10 seconds. turn key to off position..close door...turn on car.
should reset the light =)
Old Aug 17, 2005 | 09:37 PM
NiZMo1o1's Avatar
Dang Nab it.. I try to both of them..argh stealership
Old Aug 17, 2005 | 09:59 PM
reMaxxxK's Avatar
will try it tommorow, thnaks guys.
Old Aug 17, 2005 | 10:28 PM
Ammi's Avatar
350 Detroit Muscle
That doesn't work. Ignition way works but light comes back on a lot of the times.
Old Aug 18, 2005 | 05:15 AM
Iron Scimitar's Avatar
Tha Snatcher
I've tried this method years ago. It worked, but the air bag light always came back. I haven't tried the ignition method though....
Old Aug 18, 2005 | 12:15 PM
brettb's Avatar
O'rly
Or you can open your door turn ignition to on and jump on one foot seven times, close door. Or you can try the obd ii scanner.
Old Aug 18, 2005 | 12:29 PM
SHOman's Avatar
3) Wait 4 seconds
6) Wait 4 seconds
9) Wait 4 seconds
11) Wait 3 seconds
13) Wait 2 seconds
15) Wait 3 seconds
17) Wait 3 seconds
18) START Car
This works. Did it 9 months ago, light has not returned.
Took a few tries to get the timing down.
As I recall from my searching, pressing the door button only works on Max's prior to Gen 5.
Old Aug 18, 2005 | 04:14 PM
BewstAdd1ct's Avatar
and... you have to fix the problem before you reset the light.
anyway... from the svc manual:
CAUTION:
Do not use electrical test equipment on any circuit related to the SRS unless instructed to. Spiral cable and wiring harnesses are covered with yellow insulation either just before the harness connectors or for the complete harness, for easy identification.
Do not attempt to repair, splice or modify the SRS wiring harness. If the harness is damaged, replace it with a new one.
Keep ground portion clean.
DIAGNOSIS FUNCTION
The SRS self-diagnosis results can be read by using "AIR BAG" warning lamp, "SEAT BELT" warning lamp and/or CONSULT-II. The reading of these results is accomplished using one of two modes - "User mode" and "Diagnosis mode".
The User mode is exclusively prepared for the customer (driver). This mode warns the driver of a system malfunction through the operation of the "AIR BAG" warning lamp and/or "SEAT BELT" warning lamp.
The Diagnosis mode allows the technician to locate and inspect the malfunctioning part.
HOW TO CHANGE SELF DIAGNOSIS MODE - Without CONSULT
From User Mode to Diagnosis Mode
Diagnosis mode activates only when a malfunction is detected, by pressing the driver's door switch at least 5 times within 7 seconds after turning the ignition ON . SRS will not enter Diagnosis mode, if no malfunction is detected.
From Diagnosis Mode to User Mode
To return to User mode to User mode is required while malfunction is being detected, switch the ignition OFF ., then back ON and press the driver's door switch at least 5 times within 7 seconds.
After a malfunction is repaired, switch the ignition OFF for at least one second , then back ON . Diagnosis mode is returned to User mode.
Checking Air Bag Operation by Using "AIR BAG" Warning Lamp - User Mode
After turning ignition switch from OFF to ON , "AIR BAG" warning lamp operates.
Compare "AIR BAG" warning lamp operation to the chart be low.
NOTE: If "AIR BAG" warning lamp operates differently from the operations shown above, refer to "AIR BAG" warning lamp operation - Diagnosis mode -, DIAGNOSTIC PROCEDURE 6 See: Diagnostic Procedures\Diagnostic Procedure 6(step 4) Then repair as necessary.
Old Jan 6, 2007 | 06:13 PM
Mikeklas's Avatar
Patsmax method below for resetting the airbag light worked great after I removed a seat on an '05 maxima
Thanks!
Old Apr 15, 2007 | 02:05 AM
GRYMESimages's Avatar
EU inside
Reset Airbag Light
WANT TO RESET YOUR AIRBAG LIGHT???
I JUST GOT DONE DOING THIS SUCCESSFULLY ON MY 99, TODAY USING THE OLD (LOST?) INSTRUCTIONS. I HAVE THEM PRINTED BUT NOT WITH ME RIGHT NOW AND I WILL TRY TO REPOST THEM VERBATIM VERY SOON.
it breaks down like this.
leave driverside door open.
turn your key to accessory and wait for airbag light to stop flashing.
once airbag light stops, locate the door open sensor switch. near bottom of door.
set a timer or have someone count to ten. (i had my Girl count and it worked fine) and press the switch repeatedly until timer gets to ten. *i tried this 4 times, and it didnt work the first three, but i think i was pushing the button TOO fast, so if it doesnt work, dont get frustrated just slow it down a little bit.
then turn the key to the midway point between accessory and off, (you should NOT be able to remove key, and radio/clock should NOT be getting power.) and close the door.
with door closed, start your maxima, cross your fingers, and enjoy the show.
if airbag light comes back on try again, if it turns off then returns later, you may have a real problem with your airbag system.
Old Apr 15, 2007 | 07:54 AM
Maxima570's Avatar
I shut mine off the ignition way too and the light hasn't come back
Old Jun 27, 2007 | 07:20 PM
thedge7's Avatar
My airbag light never stop flashing.
Is it OK to still try this reset procedure?
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
Colossus
Sep 9, 2015 05:46 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
