Bosch MAFs
Old Aug 18, 2005 | 09:32 PM
joebangaa's Avatar
Bosch MAFs
It seems like our Altima brethren are employing bosch MAFs now? what's the truth to this? i hate discussing on those boards as i never get the answer i want. my am600 died today and i'm still debating whether or not to get another one, an 00-01 MAF and mod it, or some sort of alternative... And will someone please chime in if they know if the 04 alti MAFs fit on our cars? I heard those don't break...
Old Aug 18, 2005 | 09:40 PM
lex3015's Avatar
very curious to find out about this, seems too good to be true that I might not have to worry about my MAF going bad.
Old Aug 18, 2005 | 09:43 PM
joebangaa's Avatar
well, my first one has gone bad today after i was in denial that MAF would never break lol, and who knows when the replacement will go bad. i'm just looking for a dependable alternative.
Old Aug 18, 2005 | 11:30 PM
woosh's Avatar
I once looked into this. I think Studman found a bosch replacement that electrically matched the 2K-2K1 or 2k2-2K3 MAF. Don't remember which.
The unit I came across was the Bosch_HFM5. One of the things wrong with this unit was the output voltage (5v) at WOT. Where as the 2K-2K1 MAF output approx 4v and WOT.
I heard there was a HFM4 but couldnt find a datasheet on it.
Hope that helps
Old Aug 20, 2005 | 07:39 AM
BewstAdd1ct's Avatar
Bosch hot film massair sensors require perfect depth installation to work properly. we had some cases of people putting intake 'sound pipes' on boxsters and the mounting flange wasnt machined to the correct height.
put the same HFM in a stock boxster and it works fine...
Old Aug 20, 2005 | 08:45 AM
joebangaa's Avatar
hm...i dunno i thought alti's were already using bosch maf's...and as far as i can tell, all the new alti's except the 05+ can use the same maf's as us (dealers are now replacing their broken maf's with am600s...)
Old Aug 20, 2005 | 09:24 AM
i dont doubt it, im just saying its a picky MAF, though the later versions are reliable...
Old Aug 20, 2005 | 01:16 PM
sascuderi's Avatar
We do need a "bullet proof" MAF for our cars. Wish someone would make it. I never go WOT just for the fear of "blowing" the MAF
Old Aug 20, 2005 | 01:20 PM
GBAUER's Avatar
just to let you know: you don't have to replace the entire maf at $450, you can just replace the guts for about $125. Ask your local stealership.
Old Aug 20, 2005 | 01:34 PM
and youve verified this with 02+?
Old Aug 20, 2005 | 02:53 PM
EastSideMaxima's Avatar
A swift Bimmer driver
This is true... I've found out out from my dealer...
Old Aug 20, 2005 | 03:27 PM
n3985's Avatar
大陆弟弟
Please elaborate on this, thanks.
Old Aug 20, 2005 | 04:19 PM
Sure, I was talking to the Service advisor about the MAF and he said you no longer have to replace the whole assembly which is over $470 and that you can just replace the element for $125 (approx).. which is a great relief! Im not sure if they will charge you for the ECU update...
Old Aug 20, 2005 | 04:45 PM
n3985's Avatar
大陆弟弟
Are there DIYs anywhere on this?
Old Aug 20, 2005 | 05:59 PM
not that I know of... I dont think a lotta people know about this yet...
I was pretty surprised and relieved when i heard about this...
Old Aug 20, 2005 | 07:11 PM
post part number plz...
Old Aug 20, 2005 | 09:38 PM
joebangaa's Avatar
why would you fear going WOT. now that fiddled with the intake, i've been going WOT constantly to verify my MAF woes are all gone. and they are!
Old Aug 20, 2005 | 09:57 PM
Shogunsc4's Avatar
going WOT wont blow your MAF, it blows either it is defected, from oil or vibration. I blew a total of 4 MAFs...and I'm goin back to stock now.
Old Aug 21, 2005 | 07:11 AM
sascuderi's Avatar
Because, when you go WOT you are sending more voltage to the MAF wire, which, in my opinion, over time "weakens" the poorly designed MAF. Yes the oil etc on the wire can lead to failure, but many have lost their MAF with no modification of the intake. If you notice, most people have a sudden loss of their MAF when they are quickly accelerating.
Old Aug 21, 2005 | 07:31 AM
Virus's Avatar
The original 2k2 OEM MAF for the Alti's was replaced by Bosch MAF's and it has been Bosch since they had a problem.
Old Aug 21, 2005 | 08:08 AM
joebangaa's Avatar
actually a couple days ago i thought mine was going when i punched it, turned out vibration issues were causing my MAF to act funny...reused the stock flex section from the stock airbox to connect the intake piping to the throttle body, all woes are gone! shogun, if you never did this, you should...probably wouldn't have blown ANY of your MAFs
Old Aug 21, 2005 | 08:55 AM
sascuderi's Avatar
Thats interesting. I noticed that before I installed my Berk intake the engine would shake and move when starting. (ie there was alot of free movement of the engine) but the stock intake would be still because of the flex tube.
After the Berk, the engine doesn't move at all, so I would assume more vibration is sent down the intake? (I have the Berk intake secured on the end and it seems to prevent movement of the engine. But the forces that were causing the movement must still exist and maybe cause the MAF wire to vibrate?)
Therefore do most of you think it is best to keep using the original flex tube connected to the throttle body when installing an aftermarket intake?
Old Aug 21, 2005 | 09:05 AM
joebangaa's Avatar
YES. you want the engine to move freely. also, if anyone has a PR/cattman CAI, you'll notice upon initial installation with all parts in the kit, you get a squeak sound whenever you start from a stop. this, and MAF vibrations, are all alleviated by the flex section.
Old Aug 21, 2005 | 09:27 AM
Puppetmaster's Avatar
Concerning vibration issues, I managed to reduce some of the vibration from the chassis by using rubber washers on the bracket to the mid-pipe/filter; on both the chassis end and on the filter end. I didn't do anything about vibration from the engine by using the stock accordion piece in place of the silicon from Berk, but I'm still using the original MAF my car came with so that doesn't seem to be an issue for me yet.
Old Aug 21, 2005 | 10:33 AM
joebangaa's Avatar
well, you have a berk right? with the cold airs going through the fender, i think the whole engine movement isn't good since the hole in the fender doesnt allow much free-play room. replacing the silicon from cattman made a world of difference for me
Old Aug 30, 2005 | 06:50 PM
GBAUER and EastSideMaxima, post partnumbers please
thx
Old Aug 31, 2005 | 03:07 PM
GBAUER and EastSideMaxima, post p/ns please...
TallTom
57
Oct 14, 2025 05:16 PM
-ReLLiK-
Apr 29, 2016 06:25 PM
ballerchris510
Sep 10, 2015 09:35 PM
lux97Max
Sep 4, 2015 05:42 PM
dcardello
Sep 3, 2015 11:44 PM
