View Poll Results: Do your HS Headers leak?
Yes
40.00%
No
60.00%
Yes, but it was fixed.
0%
Voters: 10. You may not vote on this poll
HotShot Owners Step In
I need to know if anyone else has had a problem with the HS Headers leaking exhaust, mostly where it connects to the main cat.
I have tried everything to fix it and it still leaks, now I need to contact HS, however I want to know if anyone else has this problem.
If you have had the leak and fixed it, how?
Originally Posted by SHAWN82
I have had a problem with them cracking at the weld. This happened on my 98 altima. Keep your eye on it.
Originally Posted by Jime
If its leaking at the flange its usually how it was installed. I throw away the gaskets and use a high temp silicon. (Permatex Ultra Copper).
I have had three sets of gaskets, installed a new cat and have tried several types of sealers.... it still leaks everytime.
I just got out from under the car, and I can not find a darn thing. The Cat is sealed up fine, along with all the y-pipe to header flanges. I just dont know. When im driving in a high gear, say around 2,000 rpm's and i give it gas, it has that exhaust leak sound.
Originally Posted by sloppymax
out of curiosity, does your cat hit the exhaust tunnel in hard cornering? i ended up going to a test pipe just because of that.
No, I put o-Ring clamps around the hangers to hold the exhaust better. no clanging at all.
Originally Posted by chris'smax
I think your hearing a sound that is common with aftermarket headers. I think it is the sound of the valves in the motor(i think that is what the mechanic said). A guy at my local shop told me it is because of the thinner guage tubing that this sound is louder which makes since. I too thought i had a exhaust leak and had it checked out and we couldn't find a single leak. I also heard this exhaust leak sound when i put my y pipe on, but it wasn't as pronounced.
I would say you are correct, however I have seen and felt the leak at the main cat.
The big problem with finding it; is it really on comes out when the car is in gear (under load). then right away you can hear it.
as a side note, i know some flex sections are louder than others but my noise is not coming from there. i wrapped mine just to make sure and i can the same noise and the same sound levels with it unwrapped.
Originally Posted by lpmaxima31
you say that you tried using three different gaskets?????who installed it????
Set one- HS supplied gasket installed by my brother at header install (my brother is a mechanic)
Set two- Nissan OEM gasket, installed once again by my brother.
Set three - Nissan OEM gasket installed by me when I installed the HF Cat.
Set four - Dont know what kind of gasket, Installed by APG Motorsports, a very well known and respected speed shop in Albany.
Same outcome everytime.
I just talked to HS and they are most likely going to send me a new secondary pipe. HS did say that my cat from Cm with the rotating flange might also make it difficult for a good seal... now I going to call them
So I talked to HS and they are paying for me to go to my local speed shop and get the leak fixed. I have an appointment for friday morning so I will post how it goes...
Originally Posted by rchun08
does this stuff happen to cattman headers
It can happen with any exhaust... Just seems to be I got one of the fluke bad ones.
Well on friday my car went into the shop....
We decided to try and fix the existing secondary pipe...
They grinded down the flange so it would sit flat and that seems to be it... no more leaky sound at all.
So thanks to John at HS for taking good care of me and really being on top of things. He called the shop, set it all up and called me back when he said he would!!
