Optima Batteries
Optima Batteries
The alternator went out in my 2K1 SE the other day and someone here suggested I get an Optima red and or yellow top battery. Is there a specific model that I should be looking for or does it matter?
Originally Posted by wngan9447
I have the red also.. from reading your post, you are replacing the alternator right? It just soulds like you're replacing the battery and not the alternator.
It wouldn't be a bad idea to replace the battery since they last an average of 4-5 years anyways and we're headed towards winter soon.
i am also in the process of searching for the optima battery that is just right for my car, i have been told that the red top is just good for starting and normal use but since i have a system, that a yellow top would be my best option,
http://carmansgarage.zoovy.com/c=3rO...oduct/OPTD3478 here is a yellow top i found on line, for a cheep price, but after shipping its about $168, does anyone know where i could find one cheeper, maybe a website that offers free shipping?
Originally Posted by PoLo
Model: D34/78
Use Side terminal posts (NOT NOT NOT GM Side Terminal Posts) to power OEM cabling and use top for the audio system.
Picture:
Picture:
Originally Posted by foobeca
On what basis are you suggesting he replace the battery instead of the alternator?
link to the product. i bought mine from a private sources.
http://www.discountcarstereo.com/detail.aspx?ID=422
grounding subs? i hope you mean grounding amps. and no, i have it ground to a hole i mad in my trunk.
You can find that voltmeter at any place that sells Stinger products, however not many shops have them in stock.
As for Optima batteries, I would not recommend Yellow tops. I work for a company that is a large Optima dealer in Toronto, and we get on average 1 yellow top per week coming in for warranty. I bought a yellow top less than 3 years ago and it died on me last month. The Red tops have been much more reliable and rarely come back for warranty, Red's also have a better warranty. Also, don't get fooled by Optima's so-called 5 year warranty. It is actually only a 1-year free replacement warranty on the Yellow. After 1 year, it is pro-rated. Which means that if your yellow top fails after 1 year, Optima will only give you credit towards another one of their batteries, in my case, they depreciated my battery so much that I didn't have any credit at all towards the purchase of another battery. I've been selling them for almost 4 years now, and I wouldn't touch a yellow top.
I ended up buying an Exide Orbital extreme deep cycle from a local auto parts store for the same price as a Red top. It is similar to the yellow, but has absolutely no lead in it, and has vents at the top so if the alternator overcharges it, it will not bubble on the sides (unlike optima's). The Exide also has built-in handles at the top & an 18-month free replacement warranty.
here's info on it:
http://www.exideworld.com/products/a...bital_XCD.html
here's info on it:
Originally Posted by maximo-SE
so this model would work the best with my 2003 nissan maxima?
"Model: D34/78"
"Model: D34/78"
I didn't know there was a problem with the yellows. red is pretty much a good starting battery and the blue is a marine deep cycle. If you have a big system or play your sytem alot at car shows get the blue, if not just get the red.
BTW, the exide battery is at sams club for $99.
I found a close to stock battery to be the red top in size 34R (available at Batteries Plus stores). It is the 34 size with the terminals (top only) "R"eversed to match the stock orientation. For a clean fit, I used an adjustable plastic hold down, new 8" j-hooks (cut length to fit), and extended the the pos. terminal connector by adding a universal terminal (PN 01045 28-7125) to the end of the pos. terminal assembly. All 3 of these pieces were standard items off the shelf at Autozone.
Originally Posted by v6guy
Get the Diehard Gold. It has more CCA than the Optima Yellow Top and a MUCH longer warranty that Sears will stick behind. Plus it's about $20 cheaper!!!
I believe that mine has 720. At the lowest it may be 700, but if I remember correctly it's 720.
bigfrank
Oct 1, 2015 12:51 PM
markevans999
Sep 10, 2015 04:29 PM
