Center Counsel removal - HOW TO??
Old Sep 1, 2005 | 10:50 AM
ikalinin's Avatar
Help me out guys!! i want to take off the counsel that has that e brake and the storage... i need to get to the sensor for the ebrake ... my brake light keeps blinking, and if you tap the dash, it goes off.. help me out guys!
Old Sep 1, 2005 | 11:19 AM
00SEMAX19's Avatar
I think you are going in the wrong direction. If you tap the dash and it goes out then your problem isn't in the consol. Does this happen at any random time hills, turns, accelerating, braking, check your fluid and make sure it's not just coming on because the fluid is low. If the brake fluid is low then you either have really worn brakes or a hydrolic leak somewhere
Old Sep 1, 2005 | 01:47 PM
icelandmaxima's Avatar
Maxima Fanatic
Its easy to take off the center console. Just take off all the screws on the outside of the console and there should be one in bottom of the cubby. Then just take off the shifter trim by prying it up and I believe there are two other screws. Then you can access the emergency brake.
gigabyte
Jan 6, 2017 06:05 PM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
