INTERIOR OVERHAUL PROJECT IV - Bone & Black, Suede Interior Worklog!!!
Old 11-17-2005, 07:44 PM
  #441
silvermax2k2's Avatar
does your stock speedo go up to 140mph, or 160mph? I know that the 2002-2003's have a 160mph, but not sure about the 2000-2001's. the reason I ask, is because if your factory gauges go up to 160, and you replace it with a 140mph, your speed will be all fuced up. just a thought metal.
silvermax2k2 is offline
Old 11-17-2005, 08:04 PM
  #442
Anarchist's Avatar
Yeah, my 2k goes up to 160 as well. Are you planning on re-calibrating the needles metal?
Anarchist is offline
Old 11-17-2005, 08:25 PM
  #443
you can't. look at the diffrence from the 140 to the 160 gauges, you will understand why.
Old 11-18-2005, 09:15 AM
  #444
twllin's Avatar
Damn this is coming out sweeeeeeeeettt
twllin is offline
Old 11-18-2005, 10:13 AM
  #445
SHIFT_om nom nom nom
Metal Maxima's Avatar
OMG, I hate my life. I'll find a way around it....or else. I'll just have to do some mental scaling...although I am very much looking forward to doing "100" in a 65 zone... Should make for some interesting rides to scare the g/f.
Originally Posted by NYPD-Arnold
Uhhh...this better be Maxima of the Month in December. In fact, this better be Maxima of the Year.
Haha, thanks, man...truth is, I don't want to put her in the running until next summer when I finish the remaining interior projects, which include:
- Glassing the dvd player into the glovebox
- Front wheel well deadening
- Control panel in sulnglasses holder
- Complete fiberglassing of trunk
...THEN, I think I will see if I can enter the annals of the legends.
Metal Maxima is offline
Old 11-18-2005, 10:23 AM
  #446
But why is teh Rum gone?
rbrown81's Avatar
Good luck to you!
rbrown81 is offline
Old 11-18-2005, 11:00 AM
  #447
Suspension Yoda
djfrestyl's Avatar
[Butthead] Huh huh huh...he wants to enter the annals of legends [/Butthead]
djfrestyl is offline
Old 11-18-2005, 01:33 PM
  #448
PandaXpress's Avatar
METAL....im still waiting for a pm on the size LEDS that you used..and your input about the passenger door switch...come on man..been like a week..you said you get back to me.
PandaXpress is offline
Old 11-18-2005, 01:58 PM
  #449
NewLoveI30's Avatar
Hey Metal,
Are you just trying to get your guages to be black and white like the rest of your interior? If so, you might want to look into a 00-01 I30 guage cluster. My guages are all bright white along with the needles. The plastic window is also tinted giving it a really clean look while on or off.
Just an idea, if this is in fact what you are going for. It may be a direct swap as well. I know people have put an 02-03 I35 cluster in an 00-01 I30, and it was straight plug and play.
NewLoveI30 is offline
Old 11-18-2005, 02:10 PM
  #450
Slugging along...we see the 4 194 bulbs installed. Polarg, of course, since they undoubtedly give off the most light of any 194/LED bulb I have played with, and I've played with just about all of them.
Cleanliness is next to godliness when it comes to soldering.
Now I am attaching a blue light to color the backside of the needles. The LEDs have a 560-micro ohm resistor attached to each line, then each leads shrink-tube wrapped for an insulated line.
...so here's how the 4 LEDs look attached to the base of each respective needle base.
Old 11-18-2005, 02:12 PM
  #451
I attached each of the LEDs using a wire-tie and have the beam aimed at the needle base.
Old 11-18-2005, 02:14 PM
  #452
Lastly, here are the connectors I will be using to splice into the OEM wires...as you can see, this will allow me to switch between either my 5th gen or 4th gen cluster with ease.
...then I had to strip all 30-some wires, crimp the connector, then solder the wire. THIS SUCKED.
...alright, that's it for now...more pics and updates as things carry on!
Old 11-18-2005, 02:50 PM
  #453
xTeCaOx's Avatar
with this ive wondered for a long time wether i could solder a light to cover that whole part that you covered.... and will it work like that then??
thats why i havent done my radio and ac unit with leds yet because i was not sure on how to solder them in
xTeCaOx is offline
Old 11-18-2005, 03:03 PM
  #454
Well, with those lights, you need to remove the OEM ligt, and simply solder a gegular LED into the OEM bayonet housing...then what you need to do is solder a resistor on the (-) side of the led, then simply screw it in...not too tough, I may get a how-to up on this when I go back and redo mine again.
Old 11-18-2005, 03:11 PM
  #455
xTeCaOx's Avatar
hmmmmm im not sure i follow you on that... so i unscrew the oem bulb, take the bulb out of that little black plastic peice, fit a led in and solder a resiter on the neg?? then itll screw back in like normal??
xTeCaOx is offline
Old 11-18-2005, 03:16 PM
  #456
Yep! You will see on the bayonet connector that there are two little metal contact points that make contact with the PCB. When you screw it in, these points touch. SO, what you need to do, is solder the LED such that the LED pos and neg touch these points on the bayonet connector, screw in, and viola, you're done!!!
Old 11-18-2005, 03:24 PM
  #457
xTeCaOx's Avatar
oh man its that easy!!!! i would have done this a long time ago if i knew damn it, also what type of resistor do i need for that?? and a 5mm led should suffice or should i get a 3mm
xTeCaOx is offline
Old 11-18-2005, 03:31 PM
  #458
5mm LEDs + 560 micro-ohm resistors FTW!
Old 11-18-2005, 03:36 PM
  #459
xTeCaOx's Avatar
cool thanks alot man and if you do get that write up, lemme know
xTeCaOx is offline
Old 11-18-2005, 04:46 PM
  #460
merovi's Avatar
hey metal, how does the cluster look when you just replace the bulbs with either LED's or the polarg? I am wondering because i hate the stock green color but i dont want to have to pull apart the gauges and sand anything. I am really not comfortable with pulling the needles off and taking it apart. But I have done the LED's in my climate control so i have no problem replacin the bulbs. I also have chrome gauge rings on the way so I have to pull it apart sometime.
merovi is offline
Old 11-21-2005, 10:56 AM
  #461
Maxima.Org's Official Lurker
2 MaXiMuS 4's Avatar
bump for pics
2 MaXiMuS 4 is offline
Old 11-21-2005, 10:35 PM
  #462
metal..NICE PICS..thx for finally responding to my question about the leds...MORE PICS ARE NEEDED IN YOUR PROGRESS>...kepp up the good work buddy
Old 11-21-2005, 11:28 PM
  #463
The Visionary...
Split Level's Avatar
Beautiful car...I just have a couple of questions. What do you do for a living, and where did you elarn to do all this stuff? Is it trial and error or do you know someone that deals with electrical and fiberglass and everything. I would like to start customizing my car. But I wouldent have any idea how or where to start. If there is aother site or something that has d-i-y car projects that can get me familiar with fiberglassing and installing legs I would apreciate it. Once again very nice job with your car.
Split Level is offline
Old 11-21-2005, 11:41 PM
  #464
2 Da Max's Avatar
Damm Dan thats alot of work
i too vote for MOTM!
2 Da Max is offline
Old 11-22-2005, 04:20 AM
  #465
I have a Bachelor's degree in Chemical Engineering...and yes, all of this weas basically trial and error. As an engineer, I guess the only difference is that I guess I am somewhat more methodical in my modus operandi, but that's about it. Believe you me, I must have wasted +$300 on materials before I got some of this to work.
Old 11-22-2005, 04:28 AM
  #466
EdgeX's Avatar
stop braggin bout being an engineer....im an engineer too, its not all its cracked up to be
anyway, love the way the project looks, and respond to my PM man, I need to know bout friday, and speaking of friday, I can't come before noon, I have a funeral from 9-12
so just let me know when you wanna meet up man
EdgeX is offline
Old 11-22-2005, 05:20 AM
  #467
Tha Snatcher
Iron Scimitar's Avatar
longest thread eVar!!!
Iron Scimitar is offline
Old 11-22-2005, 06:06 AM
  #468
Bah, there's more, though...
REMAINING ITEMS
(I) Retrofit 4th gen cluster
(II) Install LED rocker switches for lights into sunglasses console
(III) Fiberglass DVD player into glovebox
(IV) Reupholster driver seat
(V) Dye sunvisors, paint plastic parts & install LEDs in lights
DONE.
NEXT YEARS ITEMS
(I) Fiberglass kickpods for midrange
(II) Fiberglass tweets into sailpanels
(III) Fiberglass midrange woofers into sealed enclosure in door
(IV) Complete fiberglassing of trunk w/ 2 Alumapro 12s, Arc Audio 4150, 2500, & 2100-XXK, Alto Mobile Drive 30 Digital Processor
...then...THEN I'm done.
(I) Fiberglass
Old 11-24-2005, 11:31 AM
  #469
Reverse engineering SilverMax2k2 dome light...
20 20,000MCD leds on a PCB.
...and it works!!!
Old 11-24-2005, 12:06 PM
  #470
...and it works!!!
Thanks for the credit! looks good, I did mine a diffrent way however.
Old 11-24-2005, 03:11 PM
  #471
merovi's Avatar
where can I get 20,000 MCD white LED's? lol
merovi is offline
Old 11-25-2005, 12:34 PM
  #472
eBay, man!
More pcs coming up tonight...along with a HOW-TO on the dome and mpa bulbs using LEDs
Old 11-25-2005, 12:43 PM
  #473
HotshotVQ35's Avatar
wow..amazing work!
HotshotVQ35 is offline
Old 11-25-2005, 01:26 PM
  #474
DcMaN's Avatar
your a crazy man, yes you are. Looks great wish i had the money to let you fiberglass my trunk :P
DcMaN is offline
Old 11-25-2005, 03:52 PM
  #475
Alright, pic are going to have to go up tommorow...map light is finished, dome light is fabricated...but not getting power...I have a party I need to get to, soooo...pics tommorow
Old 11-25-2005, 09:28 PM
  #476
merovi's Avatar
so when you wire the LED's in a series along the board...how do you know which side of the dome lamp ends are + and -. Does it matter? Whenever you put the dome bulb in it never matters so is it the same with the + and - of the LED's?
merovi is offline
Old 11-26-2005, 02:06 PM
  #477
No time to fawking post....grrrrr....teasers for now...
Old 11-26-2005, 02:55 PM
  #478
2 Da Max's Avatar
Nice work Dan, make me a set of those leds and ill buy it!
2 Da Max is offline
Old 11-26-2005, 03:02 PM
  #479
gec
Looking good metal --- getting close to the finished product....the guage speedo pin can be set to the new cluster...so go with it...
Old 11-26-2005, 04:28 PM
  #480
tastey wheat
mendon99's Avatar
looks awesome man, you shouldve tried Blacklight LEDs, that would made your white interior part bling!
mendon99 is offline
Quick Reply: INTERIOR OVERHAUL PROJECT IV - Bone & Black, Suede Interior Worklog!!!
