Strange Noise won't stop
Old Sep 11, 2005 | 03:14 PM
STUDIO MAX's Avatar
Hi all,
I hear this winding noise coming from the hood. It normally shuts off about 3-5 seconds after turning off the ignition, but now the noise just won't go away.
Any suggestions/links what might be the problem?
Thanks!
Old Sep 12, 2005 | 03:03 PM
BewstAdd1ct's Avatar
you could describe the noise for us...
Old Sep 12, 2005 | 03:32 PM
Rob01ski
Originally Posted by STUDIO MAX
Hi all,
Thanks!
Dude try tightening your belts cause thats what it probably is, or just replace them car will run nicer if you replace them
Old Sep 12, 2005 | 03:42 PM
BP's Avatar
BP
it could be a tumor
Old Sep 12, 2005 | 03:53 PM
belts? do the belts keep spinning 5 seconds after the engine is shut off?!
meh... im leaning toward the electronic motor mounts, some seem to have a problem with them, but if ANYONE is gonna attempt a guess at this, well need a description.
Old Sep 12, 2005 | 06:01 PM
BLUEMAX01SE's Avatar
We have electronic motor mounts ( dont ask me how they work, hell I didnt even know motor mounts can be electric ) My car makes the sale whinning noise for about 3 seconds even after you shut the car off. Dealer said it was the electronic motor mount, just haven't had the $$$ to get it repaired. Good luck!
Old Sep 12, 2005 | 06:26 PM
they get soft during idle and below 1000 RPM for smooth idle, and firm up above that for response/etc. also veh speed is tied in somehow.
Old Sep 12, 2005 | 07:01 PM
so should this noise be normal then? or does it mean the electronic motor mount is going bad?
Old Sep 12, 2005 | 09:20 PM
Patsmax's Avatar
Maybe it's your radiator fans going bad trying turning the fans with the vehicle OFF and see if they spin freely if not it's the bearings inside motor fan. When you turn the car off the fans spin for couple seconds, hope that gives you same ideas.
Old Sep 13, 2005 | 07:04 AM
kvk2003max's Avatar
Electronic engine mounts or the ECU malfunction. In my case it turned out to be the ECU and it burnt. No noise after the ECU was replaced.
To exactly describe the noise it is kind of like the sound that comes when you stick a bill in a vending machine.
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
D Mason
Jun 21, 2016 04:43 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Sep 27, 2015 08:37 AM
