able to repair muffler rear pipe?
Old Sep 13, 2005 | 05:54 AM
MrPoisse's Avatar
my mechanic tells me I have a hole in the rear pipe, and that I have to change the whole end...
for now, the sound is not too loud, but if it gets worst, I would like to know if I can repair it or if I do have to change the entire muffler section.
As you can see, its near the joint between the rear and mid pipes.
Joint - view1
Joint - view2
Btw, I have a 2000 Fed specs Manny Max.
Thanks for your input.
Old Sep 13, 2005 | 05:58 AM
NismoMaxm's Avatar
yeah sure you could weld it or what not. But my advise man since it looks that you still have the stock rear section on is to just buy a whole new catback from frankencar or cattman. or you can jsut buy a new rear section from either of them too. They have very very nice tones to them both. Not loud and ricey like the greddy.
Old Sep 13, 2005 | 06:47 AM
jimmycapp's Avatar
my pipe broke right at the fitting, right after my header install. I brought it to Midas, and had them cut off the fitting and weld a sleeve over it. At some point im getting the franken cb but untill then, it was $50 well spent.
James
Old Sep 13, 2005 | 07:33 AM
instil's Avatar
Tons of praise and gratitude to anyone who can help me!!!!!!!!!!a similar thing just happened to me and theyre telling me to cop a whole new muffler for $289!!!!!!! goodgod
Mine broke right at the part where it flanges out, and apparently that pipe is all one part of the muffler, so i cant just replace that one small section of pipe. Now im not talking a hole in the pipe, it broke free completely, so my exhaust now exits just behind the passenger side rear wheel.
Is there anything i can do besides get the whole new muffler section? a young man is broke these days...i was thinking more along the lines of $200 MAX for the whole repair, NOT $289 for a muffler, and another $100 labor.
Old Sep 13, 2005 | 07:56 AM
jimmycapp's Avatar
Mine "popped" out in the same fashion. Do what I said. Faster and Cheaper.
Old Sep 13, 2005 | 08:15 AM
instil's Avatar
dude i went to midas also and they didnt give me the cheap alternative you got from them.
im trying to follow what you said but "cut off the fitting" i dont know what you mean. ignorance is not bliss.
for clarity....look at the pic MrPoisse posted, view#1.
My pipe broke right where those bolts are, clean and flush from the piece that is bolted.( i think this is what happened to you too,correct) So the two diamond shaped pieces are still bolted together, but the round pipe isnt connected to it anymore. So what did you have them do?
Old Sep 13, 2005 | 08:40 AM
jimmycapp's Avatar
You are correct, mine did the same thing. the "fitting" i was talking about was the two diamond shapped pieces. It took them about a half hour to do. They just cut the diamonds strait off , so the pipe off the muffler that popped off looks just like the b-pipe. Then they took a metel sleeve and welded it between the two pipe,( replacing the two diamonds.) Hope this helps.
I believe it was $53 and it took about 35 minutes.
James
Old Sep 13, 2005 | 09:49 AM
instil's Avatar
i understand perfectly. thank you. Im gonna go back and tell them to do that...or nothing because i dont have $400. How is it holding up for you, btw?
Old Sep 13, 2005 | 09:50 AM
jimmycapp's Avatar
no problems so far. Been about 2 months.
James
Old Sep 13, 2005 | 03:52 PM
Mrdz03's Avatar
Can anyone help? I need a muffler for a 2000 infiniti I30. I put an aftermarket one on which was a cut and weld job and now thats breaking and no one will put the OEM one back on. Not to mention it was way to loud for my car.
Old Sep 13, 2005 | 04:39 PM
Y2KMaxGXE-R's Avatar
haha i have the same problem as you guys are having, isnt it weird???
and Midas would do a "patch" for $100. What they would do is hack a piece of my perfectly good B-pipe and weld a sleeve over it. Same issue, I do not want to spend that much on a muffler and want to stay stock.
Is there an aftermarket rear section pipe available for sale anywhere? The car is very loud, sick of it....
Old Sep 13, 2005 | 04:57 PM
irish44j's Avatar
retired moderator
I think most of us have had this problem. My stock muffler went bye-bye a few months ago (rusted through in the same spot as yours) so now I have the frankencar....nice looking, quiet, and STAINLESS STEEL so I don't have to deal with this BS again.
Old Sep 13, 2005 | 07:38 PM
Mrdz03's Avatar
so would you recommend buying the whole system or just the muffler. Does it help performance or rob it? Right now this muffler feels like its draggin my car down.
Old Sep 14, 2005 | 04:29 AM
jimmycapp's Avatar
My dads 96 had the same problem, same spot. Happend probably 2-3 times. Weak connection + stress point = weak exhaust point
Old Sep 14, 2005 | 05:54 AM
instil's Avatar
theres not even a hanger there holding the pipe. The two pipes connect, and its held *somewhat* by resting on a bar,directly over the axle.
Also, this mechanic up at midas said he constantly sees this same exact problem wit maximas.
Old Sep 14, 2005 | 09:08 AM
the aftermarket muffler does not come with rear section pipe, correct? besides, any aftermarket exhaust is louder than stock, you're maybe gaining a bit low end but loosing higher end, and 2-3 mpg worse.
JRod28
Dec 29, 2023 09:56 PM
Matt93SE
May 24, 2019 02:58 PM
Huttig2009
Sep 25, 2015 03:31 PM
erictown
Aug 20, 2015 08:01 AM
doobadoo
Aug 15, 2015 06:43 PM
