How do you change the fog light bulbs?
Old Sep 15, 2005 | 10:55 AM
higney85's Avatar
I can't seem to reach them- any suggestions?
Old Sep 15, 2005 | 11:00 AM
Puppetmaster's Avatar
Did ya try taking off the splash guards?
This write-up is for a 2002-2003, but it might be similar:
http://www.moodym.com/maxima/tech/foglight.html
Mizike's Avatar
This should do:
http://www.innerbean.com/housecor/
Old Sep 15, 2005 | 12:53 PM
juniper9803's Avatar
If Its Like 02 Pull Wheel Off Makes It Easy To Get At
Old Sep 15, 2005 | 12:59 PM
higney85's Avatar
minor detail... its a 2000- all the links seem to be for 02-03. Sorry but does anyone have suggestions for a 00?
Old Sep 15, 2005 | 01:23 PM
upstatemax's Avatar
Pull back the splash guard under the housing. you will see a bolt that threads into the bottom of the housing, take it out. Then there is a white plastic piece on top of the housing that you need to just push out of its hole and then the housing comes right out. the rest is pretty simple, I would just put your hand in front of the light when you push it out because it can hit the ground and break.
Old Sep 15, 2005 | 01:53 PM
sublimer's Avatar
is the process the same for an AE with a front lip?
Old Sep 15, 2005 | 07:56 PM
upstatemax's Avatar
I would think so, I dont have a lip so I cannot tell you for sure.
vingodine
45
May 21, 2016 12:46 PM
EuroDriver
Sep 14, 2015 06:08 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
MikesChevelle
Aug 6, 2015 11:36 AM
