Need Help With Bose Subwoofer Malfunction
Old Sep 15, 2005 | 11:46 AM
jenk01SE's Avatar
Has anyone determined the cause and fix to the Bose Subwoofer cutting in and out? I hear a faint 'pop' when it cuts out. Usually after a minute or so it comes back on.
I searched and found some threads on this topic but none suggested a cause and fix.
Old Sep 15, 2005 | 12:17 PM
MObruin's Avatar
It could be that you're pushing it too hard. Remember, its a Bose system, but its still stock. I don't think they were meant for thumping!
-MO-
Old Sep 15, 2005 | 12:58 PM
DesiGLE's Avatar
The Boy Wonder
-MO-
lol Looks like first thing I do when I get my license is get that bose system replaced before I start driving
Old Sep 15, 2005 | 02:03 PM
jenk01SE's Avatar
-MO-
It happens even at partial volume settings...and it just started happening last week.
Old Sep 15, 2005 | 09:07 PM
MaxBoost925's Avatar
Drug Money
Maxima's are notorious for radio malfunctions, go Alpine!
Old Sep 15, 2005 | 09:21 PM
mastah's Avatar
if you hit it when it goes out it should come back on... that happens on my friends... after about a month of hitting it stays on pretty consistently now... i think it stays on longer when the bass is not turned up all the way... just leave it near the middle. he took it to a dealer once and they told him that the amp might be dying which is a possibility and it would cost him like $150 to send it into bose to get it checked out
Old Sep 16, 2005 | 07:12 AM
chr0nos's Avatar
'pop' usually means some sort of ground point is not grounded well. check all your wire connections, and take an x-acto knife and scrape all the terminals to get a good ground point.
i had a similar problem with aftermarked subs cutting out. the ground wire connected to my ground screw was not in all the way, and it kept giving me a 'pop' sound every time ground would disconnect.
Old Sep 16, 2005 | 08:27 AM
boondoxmax's Avatar
I keep my bass at zero. The sub gets to muddy in sound if you have it above 0. I don't know what all the fuss is about the bose system i kinda like it. If your rocking hip hop then this system is not the best. I listen to mostly R&B and it sounds just fine. Knock on wood but no problem with my Bose yet...........
chisam14
Nov 6, 2018 08:56 PM
Fbana41
Aug 29, 2016 12:18 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
