HID Glare remarks...
Old Sep 15, 2005 | 04:45 PM
Kruppa's Avatar
I just had a post on my 2000 Maxima with the stock reflector housing and the 6000k Helios H4 Hi/Lo HID kit and i had so many comments about glare but decided if i lower the beam it should be okay, but then I saw this and got all excited...
http://www.casperselectronics.com/Me...Category_Code=
"This adapter allows the D2S or the D2R HID bulb to be used on a standard H4 headlamp housing, such as motorcycle or aftermarket automotive style housing. Has correct beam alignment shield to project light from the HID lamp to the road, eliminating upward glare. Perfect low beam disbursement is achieved with a clean cut-off point"
PERFECT!
but it gets better...I then look at the custommaxima website because I know they sell the Helios kit and what do you know...
http://www.customenterprise.com/TEST...D/ballast2.jpg
Look at the left side in the middle picture (H4 glare resistant shield)
There is no point to get the above shield from casper because if you look at the picture, there is already that same metal device along the length of the H4 bulb that prevents the glare
Do you put that metal rod on the top of the bulb to prevent it from going into ppls eyes i'd assume so right?
Old Sep 15, 2005 | 06:30 PM
wikidminds's Avatar
wud that work for 9004 housings also? i have a 4th gen with a "custom hid rig" using the sam ebulbs u mentioned. wud that glare shield work for me?
Old Sep 15, 2005 | 09:04 PM
MaxBoost925's Avatar
Drug Money
Is there a way to change the rings on projector housings to HID or different colors? I have stock lights.
Old Sep 15, 2005 | 10:26 PM
SHouKan's Avatar
Kruppa, how bad is the glare without the shield. I was planning on getting PnP HID for my 2k1 max but the glare situation is holding me back. Do you have any pictures of the cutoff against a garage door or anything. I heard the 5th gens are not as bad as the 4th because the filament of the H4 bulb is vertical like the HID's. Thus the reflector doesn't scatter the light as much as the 4th gen. Debating if I should get the projectors
Old Sep 15, 2005 | 10:28 PM
Kruppa's Avatar
Hah i'd never get projectors or any retrofit...ugly as sin in my opinion i've seen so many and i don't like any of them...I don't have the kit yet...coming in mail tomorrow...hopefully install it shortly after...i'll take pics on a wall if it ever stops raining
Old Sep 16, 2005 | 01:56 PM
gsumax's Avatar
glare on the 5th gen isnt as bad as the 4th, but the light output still isnt great. I put some on momentarily and had a little less output than the halogens, i then decided i had to do a retrofit or get 2k2 lights. (went with 2k2), i wanted to do a retrofit because the output is even better with a projector hid than reflector, but the work kinda kept me away from attempting it.
Old Sep 16, 2005 | 02:38 PM
Italiano's Avatar
SWIFT_Navigator
so it is possible to get the 2k2 headlights and an HID kit(for a more intense bulb) for the 2000 model maxima? i keep reading warnings about how it will melt the fixtures and all this other bs, but getting the 2k2 headlights solves this problem correct?
Old Sep 16, 2005 | 03:22 PM
gsumax's Avatar
you wont need a kit if you have the 2k2 headlights (they already have ballasts with ignitors built in), if you want a more intense bulb, you can just buy some aftermarket ones. The supply of d2r bulbs, (the one 2k2 uses) is a little scarcer than d2s, but im sure you can find the right intensity your looking for, although i wouldnt recommend anything over 7k. you wont melt anything as hid's run on a lower wattage. it just requires some splicing into your stock wiring
Old Sep 16, 2005 | 03:23 PM
Kruppa's Avatar
The 2k2 uses D2S bulbs, not D2R bulbs.
Old Sep 16, 2005 | 03:26 PM
gsumax's Avatar
other way around, the "r" stands for reflector, as in the type of HID headlight the 2k2 has
Old Sep 16, 2005 | 03:46 PM
Kruppa's Avatar
If you have a 2002 Maxima with HIDs you buy the D2s bulbs as replacement bulbs...not D2r
Old Sep 16, 2005 | 04:11 PM
gsumax's Avatar
read this
http://forums.maxima.org/showthread....light=d2r+bulb
Old Sep 16, 2005 | 04:32 PM
lowincash's Avatar
No More Maxipad
02-03 maxima uses D2R which is for reflector housings...D2S are for projectors housings like the ones on the 04+ maxima's
Old Sep 16, 2005 | 04:33 PM
Kruppa's Avatar
Igor911 has D2s replacement bulbs on his 2002 maxima...i dunno how that's possible then?
Old Sep 16, 2005 | 04:35 PM
lowincash's Avatar
No More Maxipad
i guess you can modify the base of the bulb to fit it because D2R bulbs will only fit reflector housings...the base on the D2R and D2S are different.
Old Sep 16, 2005 | 05:01 PM
gsumax's Avatar
also there is a light grey coating on d2r bulbs to not concentrate the light like d2s bulbs in projectors
Old Sep 16, 2005 | 07:11 PM
SHouKan's Avatar
so Kruppa, are you gonna use your stock housing or you gonna get the 2k2-2k3 housing for your HIDs.
Old Sep 16, 2005 | 09:10 PM
Kruppa's Avatar
stock housing for sure...don't wanna spend money on 2k2 housing and all projectors/retrofits are fugly in my opinion...i'm not real worried the 5th gen housing isn't bad bc of the vertical filament thing and the glare shield on the H4 bulbs will combine to make it work out fine i think...i know a 12k kit (statistically the worst output) of a friend is brighter than halogen significantly and the glare isn't bad (not bulb shield either) but headlights a little lowered so i'm not too worried...i'll post pics when i install them
Old Sep 16, 2005 | 09:32 PM
SHouKan's Avatar
cool deal... cuz I want to do the same thing. I'm probably gonna try to get a 6000K HID kits and like you, I don't want to draw attention from cops. I'm probably gonna just lower my headlights. BTW do you know where the **** is to adjust the headlights?
Old Sep 20, 2005 | 08:21 AM
SHouKan's Avatar
Hey Kruppa, did you get ur kits yet. are the bulbs D2R from custommaxima.
Old Sep 20, 2005 | 08:27 AM
Kruppa's Avatar
Yah it's at home but I'm at college and haven't had time to install it yet. yes, the bulbs are D2R from custommaxima but its the same kit you can get for much cheaper in the group deal forums so get it there and it has a lifetime warantee from maximabest in the group deal rather than a 1 yr warantee from custom maxima
Old Sep 20, 2005 | 08:39 AM
MIXXMAX's Avatar
Just to clear things up if anybody is confused about this thread...the 2K2-2K3 headlamps use D2R bulbs, not D2S. The D2R bulbs are used for reflector headlights and the D2S are used for projector lamps. The bases of both bulbs are totally different, solely on their recommended purpose. A shield is used for the D2S to reduce glare, whereas the D2S does not, because it sits behind the projector lens. Here, read this interesting article...
http://faqlight.carpassion.info/hl-hid-bulbs.htm
Old Sep 20, 2005 | 10:47 AM
gsumax's Avatar
also, as far as I can tell by the pics, the helios kit in the GB are rebased d2s bulbs.
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Vistance
Sep 17, 2015 05:17 AM
