Keep Blowing the Fog Light Fuse?? What could it be??
Old Sep 21, 2005 | 08:23 AM
GreyGoose's Avatar
I bought my car about a month ago and I noticed recently that my fog lights were not lighting up. I checked the fuse and noticed that the 15amp fuse was blown so i replaced it. It worked for about an hour and then they went out again. So the next day i checked the fuse again and it was blown again. So this time i tried a 20 amp fuse and figure it should be fine after this. same thing again fuse blew out . Does anyone have any idea what it could be??
Old Sep 21, 2005 | 08:28 AM
danger300z's Avatar
maybe a bad ground!!
Old Sep 21, 2005 | 09:00 AM
n3985's Avatar
大陆弟弟
High wattage bulb maybe?
Old Sep 21, 2005 | 09:07 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
you have a short somewhere.. take the fogs out and check the housing and check all the cables and connections
Old Sep 21, 2005 | 09:11 AM
crispykid717's Avatar
Bigger than Jesus
First of all do not use a higher amp fuse. This same exact thing happened to me just a few weeks ago. I had a bad connection on the wire coming from the relay box. I redid the connection and they lit up. Check all your connections and you should be fine.
Old Sep 21, 2005 | 05:37 PM
BewstAdd1ct's Avatar
omfg....
okay, first off you have an excessive current draw, not a high resistance, so bad grounds, poor connections, low voltage, etc are out.
youre looking for wire chafing or damage or possibly a bulb (ive seen it happen).
do NOT put a higher current fuse in. unless burning your car to the ground interests you.
can you get it to blow consistantly? try disconnecting the bulbs and going for a drive and see if the fuse blows.
The Frye
Sep 2, 2021 11:03 AM
pktaske
May 6, 2016 07:49 AM
Pnjboyzz
Sep 4, 2015 09:04 AM
pktaske
Sep 4, 2015 08:40 AM
mikebla
Sep 3, 2015 05:37 PM
