way to improve radio signal strength in aftermarket HU?
Old Sep 27, 2005 | 08:12 AM
EdgeX's Avatar
Hey guys, when I installed my headunit months ago, I didn't give a second thought to my crappy reception becuase I had my Ipod hardwired to my headunit.
But now since I am driving to work every morning, I need to listen to Preston and Steve, and My signal keeps fading in and out, is there anyway to improve the strength of the signal?
Any help would be greatly appreciated
Old Sep 27, 2005 | 09:22 AM
Progress's Avatar
It's business time.
Some aftermarket HUs have powered antennas. Maybe yours needs to be switched on. My AVIC-N1, when I had it , had a problem with the radio and I took it back to the shop that day and powered it on and it worked after that.
You may want to take this to the A/V Electronics section for more expert advice.
GL
Old Sep 27, 2005 | 10:53 AM
chr0nos's Avatar
u can also get an aftermarket antenna that goes on the ouside of your car. ususally its a think strip of metal, or wire coiled together. it goes on teh outside of your window, or somewhere on the car. you can use it instead of the oem antenna wired into the back window.
Old Sep 27, 2005 | 12:35 PM
bugbite77's Avatar
im haveing the same problems, since our car has a weird antenna conection to the stock head unit, the adapter my installer used had both connections for our weird connections (2 prong) aswell as a normal connector (one pronged), that is not connected to anything, could this be ruining my reception?
Old Sep 27, 2005 | 12:37 PM
chr0nos's Avatar
make sure the second connector is not touching any metal (ground) points in the car. it could be picking up engine noise and other electrical disturbances, and messing up your reception. i dont know if this would have a severe impact, but check to be sure.
Old Sep 27, 2005 | 12:46 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Yes. Change the station. Your body is naturally reacting to such god awful programming by causing involuntary disturbances is aural equilibrium. Change the station, and everything will be fine.
Old Sep 27, 2005 | 08:15 PM
EdgeX's Avatar
dan, you are the man, and my boy, but do NOT insult preston and steve...lol....but seriously, for a Chem E, you know a good deal bout electronics, any ideas my friend?
Old Sep 27, 2005 | 09:22 PM
bugbite77's Avatar
ill try to electrical tape it buit i was wondering if anyone has an adapter that is made for our cars, not a universal one that has these 2 plug stuff, thtas just a streight connecton adapter?
Old Sep 27, 2005 | 09:23 PM
skierxx5556's Avatar
Who listens to the radio anyway CD's are the only way to go!!
Old Sep 27, 2005 | 09:57 PM
lol...alright, to get technical on you...
Your amp is a class-D amplifier, which means that it utilizes MOSFET transistors in order to power the speakers. When power is switched in these transistors, a phenomena known as "Pulse-Wave Modulation" occurs in which a high-energy square wave is created (f-u Laplace, *******). This square wave is mostly used for energy for the speakers, but some harmonics slip through into your ground.
SO, I would go back and seriously look at your grounds. Make sure the grounds are touching BARE METAL (paint sanded off). Try this out and let us know how it works.
Old Sep 28, 2005 | 05:21 AM
EdgeX's Avatar
son of a b........you know what, I think I'll wait til we attack our little project to check all the wiring, since the dash we'll be ripped apart anyway, I can do that while you fiddle with both of our dashes....
or if i get some free time i'll do it before then.....should I check the grounds of the head unit or the grounds of my entire damn setup?
Old Sep 28, 2005 | 01:06 PM
bugbite77's Avatar
what side of the car does the antenna wire run to the back, passanger or drivers side, i think since my subs power wire is running on the driverside, if the antenna wire is on the same side, it could be causeing the static.
Old Sep 28, 2005 | 01:39 PM
2K3MAX2NV's Avatar
"tse-tse fly"
Jim,
Help.......!! I have been having the same problem for a long time!!!
Old Sep 28, 2005 | 01:47 PM
jeepik's Avatar
who listens to cd's when there is satelite radio????
Old Sep 28, 2005 | 01:52 PM
Igor911's Avatar
Your radio harness has a wire, a POWER ANTENNA wire...I think it's either blue or blue/white. Connect the radio wire to your aftermarket harness.
Old Sep 28, 2005 | 09:35 PM
bugbite77's Avatar
ok connect this radio wire to what wire on the aftermarket harnes, i went out to day to buy a new radio wire "adapter" to see if the one i have is wrong so when i do this tommorrow, and have everything apart, i would like to hook this up.(but we dnt have power antenna's, there in the rear windows?)
Old Sep 28, 2005 | 09:38 PM
bugbite77's Avatar
Originally Posted by 2K3MAX2NV
Jim,
todd, when i get this figured out, we will do this on your car too.
Old Sep 28, 2005 | 09:44 PM
Blue wire.
Old Sep 28, 2005 | 11:11 PM
spiromax's Avatar
Seoul Man
I've got an aftermarket HU tied into my stock rear window antenna using one of those antenna adapters that you guys are talking about. My reception is fine on all stations in AM and FM. I had an extra plug on my adapter too. I just insulated it and tied it back out of the way.
Old Sep 28, 2005 | 11:44 PM
The other one is for digital signals, IIRC...
Old Sep 29, 2005 | 06:54 AM
MaximaPolak's Avatar
Problems listening to little stations...like 89.5 on Sunday nights when they play club music.
Old Sep 29, 2005 | 10:16 PM
maximillien's Avatar
that wire doesn't do much, mines so bad i havwent listened to a station in 6 months...!
chisam14
Nov 6, 2018 08:56 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Sep 27, 2015 08:37 AM
