strut/shock boots ripped up, do u really need them?
Old Sep 30, 2005 | 02:11 PM
super6's Avatar
i notice that all my shock boots are torn up. i know they are meant to keep dust and stuff from getting inside the shock but i seen many people not even use them, can i just cut them off, or will dirt really make its way into the shock, do they even make any difference?? thanx.
Old Sep 30, 2005 | 02:22 PM
okay's Avatar
same with mine, what to do?
Old Oct 17, 2005 | 12:25 PM
hovak00se's Avatar
i have the same problem please shed light on this subject
Old Oct 17, 2005 | 12:55 PM
chr0nos's Avatar
half the people that lower their cars with lowering springs never put the dust boots back on. there is an inner seal inside the strut to keep the dirt out. however the elements can corrode the shiny part of you strut and it will not function as smooth, and wil eventually lead to failure (maybe). you may not run into any problems for the life of your car, or you may have a strut failue within a year.
i guess it's not life-critical to your car, but sertainly helps. you can get oem dust boots pretty cheap, and it helps keep your struts in best workig order.
Old Oct 17, 2005 | 12:58 PM
Puppetmaster's Avatar
I believe you will be fine without them, assuming you drive under normal city road conditions, but I think that the absence of dust boots just allows for more crap to come into contact with the piston and seals and increases the (small) likelihood of something interfering with the functioning of the shock. Its safer to have em, but I don't think it'd kill ya not to have em.
I did some research on and found this:
Originally Posted by Monroe FAQs
Q: I have replaced my shocks / struts several times within a few months due to excessive oil leakage. What is causing them to fail prematurely?
A. The main cause of oil leakage is seal damage. The cause of the damage should be identified and corrected prior to replacing shocks or struts. Most suspensions incorporate some type of rubber suspension stops called "jounce" and "rebound" bumpers. These bumpers protect the shock or strut from damage due to topping or bottoming. Most struts also utilize replaceable dust boots to keep contaminants from damaging the oil seals. To prolong the life of the replacement shocks or struts, these components should be replaced if they are worn, cracked, damaged or missing.
http://www.monroe.com/tech_support/tec_faq.asp
Old Oct 17, 2005 | 01:01 PM
You can get dustboots cheap from DaveB I think, and at any OEM parts places online, junkyards, etc. Or if ya wanna pay a little more, dealerships. You can get aftermarket boots from KYB as well.
Old Oct 17, 2005 | 01:10 PM
chr0nos's Avatar
speaking of aftermarket dusbtoots, i started a thread this morning about getting a dustboot with a shorter bumpstop: http://forums.maxima.org/showthread.php?t=434995
is it possible to get dustboots with a shorter bumpstop, but the top section of this bumpstop is still wider to fit into the top-hat perfectly, and let the dustboot 'hang' from the top instead of sitting on the bottom shelf of the sturt?
knight_yyz
Nov 1, 2015 01:34 PM
worldwiderecognized
Sep 24, 2015 06:56 PM
londonflu
Sep 19, 2015 02:33 PM
followthadollar
Sep 17, 2015 06:31 PM
