GLE vs. SE Suspension - Struts and Springs
Old Oct 1, 2005 | 11:32 AM
grateful1's Avatar
Am I correct in stating that the difference between the GLE and SE suspension is that the strut and springs are stiffer on the SE giving it a more controlled ride? If not, what is the difference??
I am in the process of deciding what strut/spring combo best suits my needs. Unlike many of the .org members, I have a GLE. As of about a year ago, I started to feel every bump in the road which makes it rather intolerable to drive. Is this due to bad springs, bad struts, or both?
What I really am looking for is a smooth ride but at the same time to improve the handling of the car. I want my car to be how it was before but with better handling. I have been contemplating Maxspeeds with Tokico Blues. Is this the setup I want?
Old Oct 1, 2005 | 12:45 PM
AcerX's Avatar
You're kind of like a chocolate lover that is allergic to peanut butter but is asking for a Reese anyway.
Old Oct 1, 2005 | 12:47 PM
RA030726's Avatar
I'm nutty for Nissans
not sure if its the same but 4th gens have stiffer struts and rear spings only. check with an FSM to seek the truth.
Old Oct 1, 2005 | 12:51 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
Maxspeeds with Blues will give you the same ride as stock but little lower
Old Oct 1, 2005 | 12:58 PM
grateful1's Avatar
Stock for a GLE or SE?
Old Oct 1, 2005 | 12:59 PM
grateful1's Avatar
Uh, okay. Are you saying that I am asking for something that I can't have? What exactly are you trying to tell me?
Old Oct 1, 2005 | 01:19 PM
AcerX's Avatar
Sort of. Usually but not always, vehices with good handling are not associated with also having smooth rides. But really don't take look too much into what I say. 70% of the time I'm being more sarcastic than anything, its just my nature.
Old Oct 1, 2005 | 01:30 PM
LA02MAX's Avatar
maxspeeds and blues (or illuminas, actually illuminas are preferred for their adjustability) will be a close to stock ride with a significant increase in handling, and will also reduce the wheel gap a bit...
go here: http://forums.maxima.org/showthread....hlight=springs for more reference on springs, here: http://forums.maxima.org/showthread.php?t=281189 for more reference on struts, and here: http://www.innerbean.com/housecor/sp..._decision.html for more general information about everything
Old Oct 1, 2005 | 03:36 PM
grateful1's Avatar
Thanks maxilvr06. I have already read all of these links. My problem is deciding how I want my car to feel. All of you guys that have responded have an SE but I have a GLE. I guess I still need to know what the real difference is between the two models in order to make the right decision.
So, anyone else have any insight?
Old Oct 1, 2005 | 03:37 PM
grateful1's Avatar
So let's say that I give up handling in place of a smooth ride. What would you suggest for replacement struts/springs?
Old Oct 1, 2005 | 04:11 PM
NisMoN00B's Avatar
+Cru OG
a cadillac
Old Oct 1, 2005 | 04:17 PM
LA02MAX's Avatar
alright. the difference between the SE and GLE suspension are VERY minimal...i believe the springs are a TAD bit stiffer, but it doesn't change the ride quality very much...trust me, i've been in a stock 2002 GLE before. Getting the SE springs/struts would make very little difference if that's what you're looking for...that being said, if you don't care for lowering your car even as mildly as maxspeeds, i would suggest going with the stock springs and tokico HPs for struts....the ride will be more controlled, and would either be better or the same as stock....it would also help a little in the handling department...
You're really not going to get a perfectly smooth ride in a maxima....there's just no way...but i woud think the 'smoothest' would be the setup i mentioned above...stock springs (either SE or GLE) paired with HPs
Old Oct 2, 2005 | 09:28 AM
grateful1's Avatar
Thanks again maxilvr06. I appreciate your insight and recomendations. One more question. How am I suppossed to tell when my springs are shot and I need new ones? Also, how do you know when your struts are shot?
Old Oct 2, 2005 | 09:36 AM
Progress's Avatar
It's business time.
If your struts are blown there are two ways to check. First is the most efficient and that is looking at the strut/shock itself to see if there is grease or oil on it as it has leaked. Another way and this is more subjective but if you know what you are doing you can still check this way and it is to push down on the body of the car in the area of the strut in question and if the car sort of floats after you push down and sort of bounces up and down instead of coming up and staying up, it may be blown. Springs, from what I know, don't necessarily blow. I've never heard of springs going bad, they may crack or something but that would be rare and I'd imagine fairly noticeable.
Old Oct 2, 2005 | 10:06 AM
lowincash's Avatar
No More Maxipad
i also suggest you just sticking with stock springs and get new shocks. my stock shocks were dead at about 83K and i switched them with the tokico hps all around and the ride is very smooth now. a lot smoother than my stock ones. also if you want smooth ride i think maybe different tires as well? i'm not sure if it helps but yesterday i changed all my tires since they were all bald and the ride was so much smoother. i don't feel all the bumps on the road anymore.
Old Oct 2, 2005 | 10:33 AM
serin's Avatar
i had a similar situation, when i wanted a good balance, but mostly a nice plush ride for when my wife drives the car daily. when going to mountains or a decent drive, i didn't want to be in a floaty cadillac feel to the car either.
i ended up going from a stock SE setup to GLE springs on illuminas. it really is adjustable enough to make a difference in ride quality. you have to set the rears to a predetermined compromise cuz they're kind of a pain to access. but the fronts are easy sheazy to adjust since they just stick up in the engine bay.
from the stock setup the setup is certainly more compliant, almost numbingly so. with the fronts cranked up to 5, they're too bumpy for comfortable cruising. so just find a nice middle ground.
as posted previously, don't expect a perfect ride from the maxima cuz it's just not as easy as springs/struts, but i think my setup will suit you nicely.
Old Oct 2, 2005 | 11:04 AM
DrKlop's Avatar
Driving is the next best thing
Smoother ride = stock(GLE) springs HP shocks
Near stock ride, much better handling and cornering, better looks = H&R spring illumina shocks
Progress spring with illumina shocks will give you the same affect but you’ll be sitting even lower.
Old Oct 2, 2005 | 12:42 PM
Whtmax'01's Avatar
i have found that with h&r springs and illuminas set at 2F3R in my gle gives the best combination of minimal body sway and smooth ride. When i had the front set at 3, every bump on the road was felt. And when i had the rear set at 2 the car had more body sway.
Old Oct 2, 2005 | 01:38 PM
Virus's Avatar
I have a GLE and wanted a better handling car, but didn't want a kidney bleeding experience. Several members suggested Tokico Blues with H&R springs. I tried this combo and found it to be pleasing. While it's definately harsher than the stock GLE, it's still not harsh and provides great road response. You also need to get a sway bar as it's the cheapest mod that will dramatically improve handling. I found my stock GLE suspension to be somewhat floaty and the lean into normal curves was terrible. I no longer have that problem.
Old Oct 2, 2005 | 02:26 PM
chr0nos's Avatar
springs dont usually go bad. they do start to sag as you rack up the miles on your car. if you have more than 80k, you may consider getting new springs. be it afermarket, or se or gle oem springs. the sturts start to show wear real bad around 80-100k miles. it depends on how your roads are, but even if your struts are still good at 100k, and you put on brand new ones, the ride will be much better. a lot of people have put on tokico blues with stock springs, and like the ride a lot. it gives better handling (somewhat), and better rebound than stock struts.
Old Oct 2, 2005 | 04:46 PM
lowincash's Avatar
No More Maxipad
hmm actually i felt a bit more body roll after i got the tokico blues on with the stock springs...car felt a lot softer which i'm not complaining i actually like it soft but i do feel more body roll than with my worn out stock struts =/
Old Oct 3, 2005 | 10:18 AM
HerBlue2kSE's Avatar
Just curious.. did you change tires? Say go from one brand to another or from stock 16" to 17"? Any or all of those things impact ride.
Sidewall firmness/height has more of an impact on ride that people realize.
Just my "old school" 2 cents :attention
Old Oct 3, 2005 | 05:25 PM
grateful1's Avatar
I thought that the Blues gave the car more control than stock. So how would you be able to feel more body roll if they supposedly help the car handle better?
Old Oct 3, 2005 | 05:27 PM
grateful1's Avatar
I did indeed got new tires but this problem was apparent prior to replacing them. Good thought though.
Old Oct 3, 2005 | 11:24 PM
Max'dMatt2k3's Avatar
wow 80-100k on OEM struts, on the roads out here that would be a miracle. SE vs. GLE is firmer struts, springs, and a larger anti-roll bar. all the aftermarket pieces will handle the same on a SE vs. a GLE. I went with the Illuminas and H&Rs from what everyone says Illuminas are prob. your best bet for ride and handling. I chose H&Rs for even drop + Quality product, as I have had a few cars with them and never had a problem with uneven drop or poor ride.
AaronL
Aug 8, 2020 10:31 AM
maxima-junky
Oct 7, 2015 06:13 PM
Need help
23
Oct 2, 2015 08:56 AM
followthadollar
Sep 27, 2015 01:06 PM
