Having Steering/Shimmy Issues...
Old Oct 11, 2005 | 04:16 PM
S00NR1's Avatar
OU > *
Lately I have developed a somewhat moderate shimmy that seems to be at its worst between 50 and 60mph (then goes down to slight at about 70). Along with the shimmy, I have noticed that the steering has become very loose and seems to have a mind of its own at times. My first guess is that this is a control arm/tiebar issue but I really am not sure. I just had my new set of tires mounted and balanced about three weeks ago so I don't believe it's a balancing issue. Anyone else have this issue or suggestions as to what it might be?
Old Oct 11, 2005 | 08:54 PM
irish44j's Avatar
retired moderator
sounds like a tie rod end gone bad...easy fix
Old Oct 11, 2005 | 09:06 PM
Puppetmaster's Avatar
Jack the front up, grab a wheel at 9 and 3 o'clock and give it a shake. If there is excessive play, then it is your tie rod ends.
Old Oct 11, 2005 | 09:32 PM
S00NR1's Avatar
OU > *
Ok, thanks DC gurus, I'll give that a shot in the morning.....probably couldn't hurt to replace them anyway but I was hoping to do the ES bushings at the same time as well.
Old Oct 12, 2005 | 10:57 AM
Epacy's Avatar
Unsuccesful STL Coordinator
This procedure is also used to test worn bearings.
Old Oct 12, 2005 | 11:41 AM
I believe that to check for worn bearings, you grab the tire at 12 and 6 o'clock, not 9 and 3.
Old Oct 12, 2005 | 01:13 PM
boondoxmax's Avatar
I think i am having the same issue. On the highway the steering shimmys a little and the steer feels loose. Iam figuring its the tie rods cause I am getting no noise to suggest it's the bearings. I also suspect the sway bar links as well. Gonna take it to nissan and have them check it out.....cause it's starting to drive me crazy!!!!!
Old Oct 12, 2005 | 02:31 PM
rbrown81's Avatar
But why is teh Rum gone?
Noooo dont take it to the stealership!!!!
Old Oct 12, 2005 | 02:32 PM
rbrown81's Avatar
What would you define as "excessive" play?
Old Oct 12, 2005 | 05:25 PM
rbrown81's Avatar
And is there a write up for changing a tie rod end?
Old Oct 12, 2005 | 06:06 PM
http://www.cardomain.com/ride/348507/13
Its for a 4th Gen, but its pretty much the same...
And "excessive" play means that its obvious that something is busted because your wheel(s) will feel loose.
Old Oct 12, 2005 | 06:21 PM
rbrown81's Avatar
Thanks much
picklepepper23
May 21, 2015 09:05 AM
blue_strip
Jul 25, 2014 03:25 PM
nh02max
Jun 16, 2014 08:58 AM
2248
May 30, 2014 05:44 AM
