Hissing noise-engine stalling
Old Oct 14, 2005 | 05:01 AM
nyxjf's Avatar
MY engine has been stalling frequently for a month or so. I was keep delaying on the fix. Now I have a buyer for the car and need to fix it right away.
Symptoms
- Hesitation/Loss of power- especially in high RPM.
- Hissing sound from engine bay- It seems like air leakage from somewhere. I don't know if this is normal. I haven't owned this car long enough.
- Engine stall- This is completely random. It happens at idle. Happens when RPM is falling from deaccelation/braking at a stop sign.
I have a week and half to fix this car.
Please help me out here!
Old Oct 14, 2005 | 05:21 AM
wanta02max's Avatar
sounds like a vacuum leak
Old Oct 14, 2005 | 06:05 AM
igzy's Avatar
I Know Kwaliti
yup, check the hoses, PCV, etc...
Old Oct 14, 2005 | 04:14 PM
BewstAdd1ct's Avatar
for vacuum leak, though if you have an intake, sometimes a struggling IAC will make a hiss...
ck for vac leaks first.
Old Oct 14, 2005 | 04:38 PM
nyxjf's Avatar
SOrry. I'm a Max noob. I owned wrx before. How do I check the vacuum leak??
Old Oct 14, 2005 | 05:06 PM
same way as a wrx
Old Oct 15, 2005 | 07:52 PM
nyxjf's Avatar
no vacuum leak. I checked some hoses and there's nothing. But car didn't stall at all today. Can it be fixed by itself?
Old Oct 15, 2005 | 10:47 PM
MaximaPolak's Avatar
Do you have any mods done to the car? Maybe, if you have an intake, one of the vacuum lines is loose.
Old Oct 16, 2005 | 01:03 AM
Patsmax's Avatar
did you clean out your throttle body if you did then that's where the leak is coming from. You could have leak on the pressure gasket between the throttle body and the intake manifold.
Old Oct 18, 2005 | 03:06 PM
is that all you did was ck for loose vacuum hoses? ck with brake cleaner or smoke test with the engine off...
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
sake1bs
Sep 19, 2015 09:32 PM
97_GXE
Sep 15, 2015 06:47 AM
